INNT
55
[3456789ABC][3456789AB]
0077
BOOTR2AP
Hello Janus:A0000000
====> Time: 10:49:54
USB_Init_ConfigureUSB port 0 enter power save done
USB port 1 enter power save done
USB_Init_Configure done...
Unknown flash type (0xC2, 0x20, 0x17) and use default flash type 0x0503
[msKeypad_Init]: Allocated channel number > 2 !!!
sar input test...
---- MApi_XC_Sys_Init
Sub window input source must be disabled before set frame buffer address. Ex:when video play, you canˇt use this function.
[MWE] H-SPLIT-RIGHT/H-SCAN Function
[MWE] Hstart 430 Hend 7EF Vstart 0 Vend 437
s8SN0(16) s8SN1(17)
Mirror function (0)
_COPRO_Init: u32RiuBaseAdd = A0200000
[PHOTO] Decode Memory
[PHOTO] statue, 0 --> 1
[PHOTO] JPEG, Baseline, (1366x768, 1366(1368)x768), size: 4147200, thumbnail: 0
[PHOTO] Orient: 1, Date Time: NO
[PHOTO] statue, 1 --> 2
[PHOTO] statue, 2 --> 3
[PHOTO] total time: 81, progress: 1000
[PHOTO] statue, 3 --> 0
-------------- Calibration failed.
Delete path failed
i = 0, pPath->src(34)
[_MApi_XC_CheckPostAction_OnPathChange @ 1960] YUV no exist, do EVENT_SOG_CALIBRATION ==>
[MUX] ======[path created]====== source: 34 sink: 1
==>ADC SetInputSource Count=1
_MApi_XC_PostAction_OnPathChange @ 1969, u8PostCondition_OnPathAdd(0x0)
MApp_DMP_InitDMPStat
[MWE] Hstart 70 Hend 6F Vstart 0 Vend 437
[GE] Wait Idle: 0 : 10
DSP code loaded successfully
audio DSP_DEC LoadCode success..
_GOP_GWIN_AlignChecker, This FB format needs to 4-pixels alignment !!!
Delete path success
Delete path failed
i = 0, pPath->src(23)
[MUX] ======[path created]====== source: 23 sink: 1
DVB-T Software Version: 0.00
[Board]: BD_MST6M48_SKYWORTH_QFP
[Panel]: FullHD_CMO216_H1L01
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 0
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
[ENABLE_POWERON_MUSIC]
