查看: 1437|回复: 4
RDA8501_EXT_SPI#SIP
发表于: 2018-3-29 17:42:59
RDA8501_EXT_SPI#SIP
老大此芯片是不是还没添加
发表于: 2018-3-29 19:08:19
You must download latest RT809F software in this site and correctly install.When you use it, you must manually select "RDA" letter.It is located under the manufacturers heading.After you have selected RDA,you can see RDA8501_EXT_SPI#. At this time, you must click OK.And then load the firmware file by clicking"Open" tab.And then click Write Tab.But system won't work and warn you to power off.And power on again.After you did power On and Off,the system will work normally.But you must wait very long time.Be patient,it will OK.
发表于: 2018-3-30 10:33:08
你是什么版本?这芯片早就有在线读写的啊。
 楼主| 发表于: 2018-3-30 13:36:00
别的板子isp一连就读出来了,这种不行
发表于: 2018-4-3 16:24:20
可以的  很早的软件都可以读写了
GMT+8, 2024-12-28 18:45 , Processed in 0.052862 sec., 10 queries .
