查看: 3879|回复: 5
RT809H software need to update for parallel NOR flash erase
发表于: 2018-3-10 12:10:52
I have RT809H programmer. I met a problem during programing Spansion parallel parts (S29GP256P, S28GL256S, S29GL256N,...)
I checked the operations with a sample part and found the followings.
1.      the Read Operation: the OK
2.      Verification: OK
3.      Blank check operation: OK
4.      Program operation with an empty part: OK
5.      Program operation with a non-empty part: Error
6.      Erase operation: Error
I checked the logic signals with logic analyzer on a socket board for investigating erase operation in more detail.
Based on the logic signal, Ready/Busy# signal is not going to low an all the time high after issuing Erase command into S29GL256S. So RT809H think Erase operation is completed and stopped and issue Read command to verify.
I checked Program operation with an empty part. Erase command will be issued first during Program operation. With the same reason with the above, Erase operation is not going well. However, since the part is already completely erased, the following verification operation was passed. And Then the program operation will be followed. I found Ready/Busy# signal is going to low during program operation unlike erase operation.
Can somebody check RT809H software and fix the error for proper erase operation? If more information is needed, please contact me at kjang@issi.com.
==> Sep/07 update: I checked S29GL256P on 20180630 and 20180731 version RT809H SW tool. And I couldn't see any program and erase issue.  Cleared.
发表于: 2018-3-10 13:50:16
Thank you for your information sharing.
发表于: 2018-3-18 12:41:43
汉语可好 谢谢
发表于: 2018-6-18 13:00:19
The writing and erasing of the s29gl128p tsop56 chip does not work. Please correct in the update.
Adapter RT-TSOP56-A V1.1 for RT809H PCB V1.80,Boot V1.00
001:  Serial number:201801211XXXXX-XXXXXX  ,PCB V1.80,Boot V1.00
002:  http://www.ifix.net.cn/thread-56901-1-1.html
003:  The currently selected:S29GL128P@TSOP56, capacity: 128Mbits, 16Mbytes.
004:  Adapter modelЈєRT-TSOP56-A, 0.5, 14*20
005:  Hi-ROM/OTPArea size: 2048 bitsЈ¬256 bytesЈ¬the starting position in the buffer zoneЈє0x1000000.
006:  Download device programming algorithm......
007:  Algo update OK
008:  >------------------------------------OK---------------------------------------<
009:  Chip pins contact is detected OK.
010:  Chip ID verification OK.
011:  Start erasing chip, please be patient......
012:  Erase successful&#1032;&#172;Elapsed time&#1032;&#1108;0.064 seconds&#1038;&#1032;
013:  Auto blank checking...
014:  Chip is not blank, start position: 0x0.
015:  Blank check failure&#1032;&#172;Elapsed time&#1032;&#1108;0.085 seconds&#1038;&#1032;
016:  Erase error&#1032;&#187;
017:  D:\xxxxxxxxxx_S29GL128N_xx.BIN
018:  File has been loaded, checksum: 16bits_0x7422 &#1032;&#172;32bits_0xA3257422 :
019:  Chip pins contact is detected OK.
020:  Chip ID verification OK.
021:  Start writing chip......
022:  Auto erasing...
023:  Erase successful&#1032;&#172;Elapsed time&#1032;&#1108;0.074 seconds&#1038;&#1032;
024:  Start writing...
025:  Write successful&#1032;&#172;Elapsed time&#1032;&#1108;4.119 seconds&#1038;&#1032;
026:  Auto verifying...
027:  Chip verification error, start position: 0x0.
028:  Verification failure&#1032;&#172;Elapsed time&#1032;&#1108;0.085 seconds&#1038;&#1032;
029:  Write error, operation terminated.
发表于: 2018-6-23 15:42:45
Help me. I can don't write a chip.
发表于: 2018-7-6 15:06:42
The problem is no more. There was a defect in the adapter.
GMT+8, 2025-12-15 16:06 , Processed in 0.054326 sec., 12 queries .
