查看: 1397|回复: 8
aqui disponible algunos eeprom reset Mainboard Samsung
发表于: 2018-2-18 21:33:25
Resetting the NVRAM (EEPROM) to reset TV, settings, necessary to remove the EEPROM device from the television. But it is not necessary. In the electronic world, if the communication of the chip is disabled, it counts as eliminated. So you only need to kill the communication from the EEPROM. EEPROM on Samsung TV is communicating through the common I2C protocol. This protocol carries the data through the SDA line and sends the clocks through the SCL line. In our situation, both the SCL or SDA block works. But I decide SDA.
For this, all you have to do is feed (connect) GND (ground) or VCC (3.3 V) to the SDA line with little wire ... That's it. Since these lines are high (v3.3) at rest, it is better to keep it through VCC. You can also keep through these GND lines as well. But it is not about connecting both GND and VCC. It will be short circuit and is likely to damage the plate.
Join VCC and SDA, power on television and contain about 20 seconds with the TV on. Simply try to read (badly) the configuration of the EEPROM, since it can not read anything (see in the following warning message), just start with the default values. That's what we want. That the release of the SDA line and turn off the television will update the configuration of EEPROM with null values, that the television could start with it. After all, you can enter the service menu and modify the necessary changes.
发表于: 2018-2-18 22:04:58
谢谢楼主分享
发表于: 2018-2-18 23:12:33
Thank you for your post.
发表于: 2018-2-19 13:28:21
谢谢楼主分享
发表于: 2018-2-21 11:38:12
very useful thank you for sharing.
发表于: 2018-2-21 12:43:00
谢谢楼主的经验分享!
发表于: 2018-2-21 12:55:28
送人玫瑰手有余香,谢谢楼主分享的资料...
发表于: 2018-2-21 13:37:57
虽然没看懂,还是要说声
Thank you
发表于: 2018-2-24 10:53:32
有看没有懂。
GMT+8, 2024-12-20 01:42 , Processed in 0.057115 sec., 9 queries .
