查看: 1404|回复: 3
L32F3200B MS28机芯按开机键红灯熄灭电视没反应,再按开关机键也关不了机,不变红灯
发表于: 2018-1-31 21:27:17
下面是用809F导出的打印信息,可惜都是英文,一点都搞不懂。求求各位大哥帮我翻译一下,看看这个机器故障到底出在哪里!2018-1-30, 22:7:7
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
郩ART_115200
BIST0-OK
BIST1-OK
_U
Hello U-Boot
U-Boot 1.1.6 (Oct 12 2011 - 11:02:00)
Board: MSTAR TITANIA13 (CPU Speed 504 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: USB FAT NAND UBI UBIFS NET SPI STANDBY JFFS2 LOGO ENV=SERIAL
Flash is detected (0x0A02, 0x1C, 0x31, 0x15)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 2097152
        u32SecNum      = 32
        u32SecSize     = 65536
NAND: 256 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100208768TH0000000T
EnvFlag =:164.....CONFIG_ENV_ADDR=:1E0000
0x00400000-0x0F700000 : "mtd=1"
Using volume CONFIG
UBIFS error (pid 0): mount_ubifs: can't format empty UBI volume: read-only mount
Error reading superblock on volume 'ubi:CONFIG'!
ubifs_mount FAIL !!
Mount Config -1
UBIFS not mounted, use ubifs mount to mount volume first!
keypad_pressed_1 is:0
keypad_pressed_2 is:0
keypad_pressed is [0]
ir_pressed is [0]
PowerMode is 5B ... ADD 1C0001cPowerOnOffFlag =:0xA5.....CONFIG_POWERFLAG_ADDR=:1C0002
         ->[u8PowerDownMode = 255]
         ##->Reset Pull Low...
Wait for PM51 standby...........
PM51 run ok...........
PM_Init...
==== Enter Standby Mode !! ====
UART_115200
BIST0-OK
BIST1-OK
_U
Hello U-Boot
DRAM:  256 MBytes
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
NAND: 256 MBytes
In:    serial
Out:   serial
Err:   serial
Using volume CONFIG
ubifs_mount FAIL !!
Mount Config -1
ir_pressed is [0]
         ->[u8PowerDownMode = 2]
UnProtect MIU block 0 : 0x75F1000 0x76B7000
NAND read: device 0 offset 0x0, size 0x400000
Reading data from 0x0 -- 100% complete.
4194304 bytes read: OK
## Booting image at 81000000 ...
Bad Magic Number
<< MStar >>#
发表于: 2018-1-31 21:42:20
Please try by restoring original firmware.
发表于: 2018-2-1 09:10:29
刷机试试看.....
发表于: 2018-2-1 19:16:07
nand 主程序出错,刷机。
GMT+8, 2024-12-31 03:35 , Processed in 0.048190 sec., 9 queries .
