查看: 3898|回复: 9
请求各位师傅看看康佳LED55R6610的打印信息是什么问题
发表于: 2017-12-29 19:20:11
开机有开机声音,屏亮,开机显红绿蓝屏自检模式。
2017-12-29, 18:6:35
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
R
U-Boot 2012.07-svn815094 (Mar 31 2015 - 16:54:34)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1 GiB
Watchdog: Enabled?
------------We will not Enter Recovery Rescue
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
Factory_RO: MMC
         rtk_eMMC_read blk_addr=0x00008000, data_size=0x00000200, buffer=0x07880008
[FAC_RO] No factory_ro data in eMMC
[ENV] read_env from factory failed
[ENV] Using default environment variables
Mac Address use 00:10:20:30:40:50
Panel: Use default config (tmp/factory/bin_panel/panel.bin is not found)
Panel: default_panel.h
panel_init_1st
Panel: ulFreq:149000000, nDPLL:157499520, Mcode:35, Ncode:3, offset:6e9
DispI : Finish BISR testing done
DispD : Finish BISR testing done
panel_init_2nd
***** Get Chip ID (3) *****
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0 name=PIN_KEYPAD_RIGHT ppcb_enum.Name=PIN_KEYPAD_RIGHT, ppcb_enum.info=52a000101
name=PIN_KEYPAD_SOURCE ppcb_enum.Name=PIN_KEYPAD_SOURCE, ppcb_enum.info=52f000001
======== Checking into android recovery ====
Start Boot Setup ...
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x06ff0000
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000400, buffer=0x06ff0000
  FW Table to 0x06ff0000, size=0x00000400 (0x06ff0400)
  FW Table fr 0x02000000, fw count: 9
Normal boot fw follow...
Linux Kernel:
  FW Image to 0x00108000, size=0x009e9064 (0x00af1064)
  FW Image fr 0x02008000 (non-lzma)
Audio FW:
  FW Image to 0x81700000, size=0x00254690 (0x81954690)
  FW Image fr 0x029f1200 (non-lzma)
         rtk_eMMC_read blk_addr=0x00014f89, data_size=0x00254690, buffer=0x01700000
  FW Image entry  checksum=0x0b351010
  FW Image result checksum=0x0b351010
Video FW 1:
  FW Image to 0x81a00000, size=0x002bee78 (0x81cbee78)
  FW Image fr 0x02c45a00 (non-lzma)
         rtk_eMMC_read blk_addr=0x0001622d, data_size=0x002bee78, buffer=0x01a00000
  FW Image entry  checksum=0x0916f1e1
  FW Image result checksum=0x0916f1e1
Video FW 2:
  FW Image to 0x81d00000, size=0x000b2e4c (0x81db2e4c)
  FW Image fr 0x02f04a00 (non-lzma)
         rtk_eMMC_read blk_addr=0x00017825, data_size=0x000b2e4c, buffer=0x01d00000
  FW Image entry  checksum=0x0273b9a5
  FW Image result checksum=0x0273b9a5
ECPU FW:
  FW Image to 0x00004000, size=0x000020bb (0x000060bb)
  FW Image fr 0x02fb7a00 (non-lzma)
         rtk_eMMC_read blk_addr=0x00017dbd, data_size=0x000020bb, buffer=0x00004000
  FW Image entry  checksum=0x000df071
  FW Image result checksum=0x000df071
Audio data 1:
  FW Image to 0x82000000, size=0x000085c8 (0x820085c8)
  FW Image fr 0x02fb9c00 (non-lzma)
         rtk_eMMC_read blk_addr=0x00017dce, data_size=0x000085c8, buffer=0x02000000
  FW Image entry  checksum=0x001f521b
  FW Image result checksum=0x001f521b
Video[image] data 1:
  FW Image to 0x82580000, size=0x00017fdf (0x82597fdf)
  FW Image fr 0x02fc2200 (non-lzma)
         rtk_eMMC_read blk_addr=0x00017e11, data_size=0x00017fdf, buffer=0x02580000
  FW Image entry  checksum=0x00f812f1
  FW Image result checksum=0x00f812f1
Audio data 2:
Video[image] data 2:
Enable VCPU1
Enable VCPU2
aa 0xffff0010, 0x0, 0x0, 0x0
Release HW semaphore
ABCD[BOOT_AIO][0]  0x00000000
[BOOT_AIO][1]  0x00000000
[BOOT_AIO][2]  0x00000000
[BOOT_AIO][3]  0x00000000
[AIO_PATH] use default setting!
[AIO_PATH] src_sel_aio1      =  0x00000001
[AIO_PATH] src_sel_headphone =  0x00000002
[AIO_PATH] src_sel_pcm_dac0  =  0x00000002
[AIO_PATH] src_sel_pcm_dac1  =  0x00000004
spdif raw from PB
enable_clock 34 hold_hw_semaphore
VVwwaaiitt
VCPU1: BISR testing ....
VCPU1 : Finish BISR testing done
VCPU2: BISR testing ....
VCPU2 : Finish BISR testing done
aa 0x74811a3c, 0xd8445a27, 0x8004003, 0x0
Release HW semaphore again
V2go V1go          rtk_eMMC_read blk_addr=0x0R0o01s0S04t0Raro,tsTS tadsaakrtCtTraea_asktsCeiHroezaoekt=e Ho10o3x2k
01
0V3912
e
p9kVt00 Q6 p4kt Q0,x   80x1b8du81dcf73f07e7000,r, =s 0zsz x8 0 81 0161 60 88
8
0V0 0p0k
t
Q  0xa1c77700  0xa1d8d300
[vo] Vodma(0) disable
[vo] VODMA(0) ForceBG(0)
[vo] Vodma(1) disable
[vo] VODMA(1) ForceBG(0)
VP_PowerOnVideo 39
[vo] Vodma(0) enable
~vbm create  0xa3004000, 34888
[vo] ShowChannel(p0)
POV:h264 workaround start!
~init decfilt  0xa30131b0 0->5
H264_DEC: INIT_RING_BUF_COMMAND0:
pRd= 0xa3001e84 pWr= 0xa3001e74 write= 0x83002000
H264_DEC: Unknown filter command type: 24
H264_DEC: RUN
$$dpb_bypass 0
VBM: configured to User Defined (4096, 2160)
$$dpb_bypass 0
H264_DEC: STOP
$$dpb_bypass 0
H264_DEC: FLUSH
POV:h264 workaround end!
POV: image filter testing
+++[RequestBuffer] width 1920, height 1080 ret 268435456
POV: request Buffer, Y_BufID = 1
POV: request Buffer, C_BufID = 0
POV: image filter testing Y_bufID 1, C_BufID 0
(IMG) JPEG detect!!IMG_DEC: Create Filter fmt 0
SE_SCALER_Init103): base0  0x84974000, sz0  0x00800000,base1  0x85174000, sz1  0x00800000SE_SCALER: procBuf  0x85974000, sz0  0x00400000
IMG_DEC: send cmd to Scaler
IMG_DEC: send ringbuffer cmd to Dec
JPEG_DEC: base= 0x82580000 limit= 0x82597fe8 Wr= 0x82597fdf Rd= 0x82580000
IMG_DEC: send Decode cmd to Dec
JPG_DEC: IMG_DECODE
(Adobe) set saw_Adobe_marker TRUE!!
(THUMB) IS USING THUMB 0, w 160, h 90, tgt_w 1920, tgt_h 1080!!
(JPEG) IsC 0, w 1280->1280, h 720->720, hor 0, ver 0!!
(JPEG) IsC 1, w 2560->2560, h 720->720, hor 0, ver 0!!SE_SCALER: MPO 1 0
(JPEG_COMP) IS_PROG 0!!
(SendScalerEnd) IsShowPic 0!!IMG_DEC: destroy
JPG_DEC: decode time=8025 w=1280 h=720
POV: image filter testing DONE
[vo] VODMA_SyncGen_Check: p0, pic 1
[IDMA] 3D/I3D/Sen/Src=-16777238/0/0/1
V1 pktQ  0xa1d8d300  0xa1c77700
DmaM=1
[vo] ipg1080p_frc_fhd_dibypass !!!
[vo] VODMA_SendVOInfo
ptSlrVoInfo  mode=10
h_start=140
v_start=13
h_width=1920
v_length=1080
h_total=2200
v_total=1112
chroma_fmt=0
progressive=1
h_freq=675
v_freq=600
pixel_clk=148500000
i_ratio=0
source=0
ptSlrVoInfo  afd=8
3d_mode=0
force2d=0
NULL == ptSlrVoInfo
ShowStillPicture~~
 楼主| 发表于: 2017-12-29 19:22:33
一次太多发不了,后面的
[ao_Init] ver_D
bf [SB2_INSTAT] =  0x00000000
af [SB2_INSTAT] =  0x00000000
HDMI Raw Enable: MPG AC3 DTS MPEG2 AAC DDP WMAPRO MLP
SPDIF Raw Enable: MPG AC3 DTS MPEG2 AAC DDP WMAPRO MLP
Force 2ch Format: DTS DTSHD AC3 DDP MLP AAC WMAPRO
set global  0x00000000  0x0000bb80
set global  0x00000001  0x0000bb80
set global  0x00000002  0x0000bb80
set global  0x00000003  0x0000bb80
set global  0x00000004  0x0000bb80
set global  0x00000005  0x0000bb80
set global  0x00000006  0x0000bb80
set global  0x00000007  0x0000bb80
Start Power On Music Flow
Power On Music: UsableMemory= 0x82100000, Size= 0x00480000
[AUDIO]vol = -21
skip AO output pin create
spdif fix volume shound from PB ch 4/5 path
[ao_Set_OutputSamplingRate2] fs = 48000(8)
power on music create ao ok
finish power on music create
[AO]SPDIF SELECTION: PCM FIFO
_VENUSAOUT_Run  0x00000000
PCM run
New Format!!  0x00000000, MPEG
[DEC] non_pcm_type  0x00000004, sub_data_type 0x00000000
mpg pcm ch  0x00000002 sb  0x00000020 sr  0x0000ac44 mono  0x00000000
mpg info ns  0x00000480 br  0x00000080 layer  0x00000003
[AO] chidx change point occur: rp  0xa22c0550 cptr  0xa22c0550
[AO] DAC change point occur: rp  0xa22c0550 cptr  0xa22c0550  0x0000bb80  0x0000ac44[AO][HPT]  0x00000000  0x00000002  0x00000000
============[AO][high priority task]===============
[Audio] can't call rpc during poweron music
[DAC  0x0000bb80 ->  0x0000ac44]
[ao_Set_OutputSamplingRate2] fs = 44100(7)
============[AO][high priority task]end============
[AO][PB]Enable RdAdma(v/a: 0x00001000/ 0x00006000),thd=20ms
WARNING[796296]OV: Wait system to STOP Power on Video!(bVideoDone 2)
         Kernel entry  checksum=0x39e74626
         Kernel result checksum=0x39e74626
Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=100700 flashtype=emmc mmcparts=rtkemmc:3866624k,512000k(/system),2150400k(/data),409600k(/cache),16384k(/res),409600k(/kkcustom) reclaim=64M@32M last_image=8M@96M quiet
[       0][3452 ms]  bootcode end
Starting kernel ...
[  155.634256] [linux][CBUS] MHL_init_module
[  155.638410] [linux]CBUS: register sucess!!! IRQ 57
[  155.757320] mtdoops: mtd device (mtddev=name/number) must be supplied
[  155.824485] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
WARNING[1762219]OV: Wait system to STOP Power on Video!(bVideoDone 2)
[  156.089244] EXT4-fs (mmcblk0p1): VFS: Can't find ext4 filesystem
[  156.095536] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p1 at /system
[  156.102952] init: fs_mgr_mount_all returned an error
[  156.112922] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[  156.121075] init: cannot find '/system/bin/vold', disabling 'vold'
[  156.127434] init: cannot find '/system/bin/pvrsrvctl', disabling 'pvrsrvctl'
[  156.134684] init: cannot find '/system/bin/gldcDaemon', disabling 'gldcDaemon'
[  156.142106] init: cannot find '/system/bin/keypad_tv035', disabling 'KeypadService'
[  156.149983] init: cannot find '/system/bin/sh', disabling 'rtd299x-setup'
[  156.156962] init: cannot find '/system/bin/netd', disabling 'netd'
[  156.163315] init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
[  156.170564] init: cannot find '/system/bin/mediaserver', disabling 'media'
[  156.177629] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[  156.184526] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[  156.192658] init: cannot find '/system/bin/drmserver', disabling 'drm'
[  156.199368] init: cannot find '/system/bin/installd', disabling 'installd'
[  156.206435] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[  156.215015] init: cannot find '/system/bin/keystore', disabling 'keystore'
[  156.222082] init: cannot find '/system/bin/insmod', disabling 'brcmbtusb'
[  156.229067] init: cannot find '/system/bin/sh', disabling 'kk_copy_file'
[  156.235956] init: cannot find '/system/bin/iflytekdeamon', disabling 'iflyekdeamon'
[  156.243822] init: cannot find '/system/bin/konkatouchpad', disabling 'konkatouchpad'
[  156.251780] init: cannot find '/system/bin/xcmidware', disabling 'xcmidware'
[  156.259024] init: cannot find '/system/bin/init.toltech.sh', disabling 'toltech_device'
[  156.268104] init: cannot find '/system/bin/sh', disabling 'console'
[  156.274560] init: cannot find '/system/bin/app_process', disabling 'zygote'
[AO][PB] Underflow
Power On Music EOS, wait for linux to SET_DONE
WARNING[1844757]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864336]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864592]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864564]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864328]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864350]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864348]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864586]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864538]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864465]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864248]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864211]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864400]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864389]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1864272]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
 楼主| 发表于: 2017-12-29 19:25:44
用U盘刷不了程序
发表于: 2017-12-29 20:38:41
检查屏了吗?自检请确定是主板还是屏
发表于: 2017-12-30 09:21:56
不接屏试试看,好像你的EMMC 不能完成,不接屏的LVDS 信号线看能不能正常开机......
 楼主| 发表于: 2017-12-30 15:05:43
ghhj 发表于 2017-12-29 20:38
检查屏了吗?自检请确定是主板还是屏
看显示屏是好的,不知道是逻辑板还是主板
 楼主| 发表于: 2017-12-30 15:08:38
谢谢,不接主板到逻辑板的排线,能开机,有开机声音
发表于: 2017-12-31 09:16:33
那主板应该是没问题的,屏或逻辑板的问题了  仔细查查......
发表于: 2018-6-7 19:56:58
屏自检说明屏和逻辑板是好的,能开机说明主板硬件没问题,刷个程序就好,以前遇到过。
GMT+8, 2024-12-19 17:53 , Processed in 0.054829 sec., 9 queries .
