查看: 2711|回复: 6
求助:康佳LED50X9600UE液晶电视维修
发表于: 2017-12-19 09:17:04
康佳LED50X9600UE液晶电视开机红灯待机状态,按开机键转绿灯,背光亮,屏幕灰屏无图像,有系统声音,一会自动转红灯。测试各板块电压正常,
求助分析是什么问题?
打印信息如下
閬偮灵偮艆閬偮脱?偮嵧閭洛逡偮蚜jR麵t's the last cmd箷褋櫧展懝5R:曆?
@@@@@@ u32CpuSpeedMHz= 792 MHz
msIR_Initialize
i2c write...:0x80,0x1,0x2,0x0,0x0,0x55,0x0
i2c write...:0x80,0x2,0x0,0x0,0x2,0x1,0x3
i2c write...:0x61,0x6,0x0,0x0,0x0,0x0,0x0
u8_Status ok:85..
i2c write...:0x23,0x1b,0x10,0x27,0xc2,0xee,0xd0
i2c write...:0x23,0x1b,0x10,0x27,0x40,0x40,0xd0
i2c write...:0x33,0x1b,0x10,0x27,0xc3,0xee,0xd0
i2c write...:0x81,0x5,0x7,0x80,0x4,0x38,0x0
i2c write...:0x13,0x1,0x0,0x0,0x0,0x0,0x0
i2c write...:0xfd,0xd,0x2,0x0,0x0,0x0,0x0
i2c write...:0x33,0x1c,0x13,0x0,0x4,0x40,0x40
i2c write...:0x33,0x1c,0x13,0x0,0x4,0x0,0x40
Wait for PM51 standby DRAM ...........PM51 run ok...........============= set bootargs ===============
Unknown command 'if_51OnRam_set' - try 'help'
[INFO] Load Ukulele 8x Mode DRAM Settings
Ukulele MIU BIST: OK
mmc change mount : customercfg
mingwu_mboot----vfs_getsize->filedir = /customercfg/panel/ursa/MERGE_VB1.bin
mingwu_mboot----------vfs_getsize--=000=
Size of file "panel/ursa/MERGE_VB1.bin" from mmc device 0 partition customercfg: -1 bytes
mingwu_mboot----vfs_read->filedir = /customercfg/panel/ursa/MERGE_VB1.bin
mingwu_mboot----------vfs_read--=000=
Loading file "panel/ursa/MERGE_VB1.bin" at offset 0x0 from mmc device 0 partition customercfg
** File not found panel/ursa/MERGE_VB1.bin **
[ERROR] vfs_read:546: ext4load mmc fail
vfs_read fail
fore uup IRKey [0xff]
mingwu_mboot----------get_boot_mode_from_env
mingwu_mboot------------>get_boot_mode_from_env-->ulComplete == 0
db_table.ursa_offset =:0x171cdf...db_table.ursa_size=:0x12
>>CMD:a2,2,0,0,d8,0,0
MDrv_Ursa_8_3D_Cmd write data fail.....
sellect video swap mode error!!!
>>CMD:a2,2,0,0,d8,0,0
>>CMD:a2,2,0,0,d8,0,0
>>CMD:52,1,0,0,0,24,0
>>CMD:63,23,8b,d8,0,0,0
[URSA_8]Write cmd:b5,9,2,0,0,0,0
[Ursa_8]Send cmd:9, return:0
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
LINK TYPE = EXT [_MDrv_PNL_Init_LPLL][300]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][302]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][345]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][347]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
p_str =259
u32PWMDuty =259
Init PWM1Init PWM2[ERROR] No Support PWM Clock Unit Divider in Nike Platform@@@@@@ u32CpuSpeedMHz= 792 MHz
[URSA_8]Write cmd:93,8,1,0,0,0,0
[Ursa_8]Send cmd:4, return:0
[AutoTest][MBoot][JPD Decode]
[GOP0, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0002, ChangeList: 00000340
[AutoTest][MBoot][Show Logo][7286]
[[utopia]]      DSPBinBaseAddress 0= 0x0
[[utopia]]      DSPMadBaseBufferAdr 0= 0x19100000
[[utopia]]      DSPBinBaseAddress 1= 0x0
[[utopia]]      DSPMadBaseBufferAdr 1= 0x18fc8000
[[utopia]]      DSPBinBaseAddress 2= 0x0
[[utopia]]      DSPMadBaseBufferAdr 2= 0x18e88000
HAL_MAD_SetMemInfo : DDR_ADDR = 0x19100000, MIUBank = 0
[AutoTest][MBoot][Play Melody]
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    3798547 Bytes = 3.6 MiB
   Load Address: 20208000
   Entry Point:  20208000
   Contents:
      Image 0: 3612592 Bytes = 3.4 MiB
      Image 1: 185943 Bytes = 181.6 KiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
## Flattened Device Tree from multi component Image at 25000000
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
   Loading Multi-File Image ... OK
[AT][MB][start kr][7538]
Starting kernel   ...
KERN-3.1.10.00539225
[    0.000000] SAR5=ON
[    0.031593] smp_twd: clock not found: -2
[    0.109241] CPU1: Unknown IPI message 0x1
[    0.137322] CPU2: Unknown IPI message 0x1
[    0.164930] CPU3: Unknown IPI message 0x1
[    0.225074] eMMC: has SD, 2013/0617
[    0.524612] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    0.530677] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.536013] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.542885] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    0.685052] init: could not open /dev/keychord
[    0.689342] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.694665] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.699842] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    0.706567] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.711883] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
             A N D R O I D
[    0.726613] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    1.040919] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    1.050050] init: cannot find '/system/bin/upnp_tv_receiver', disabling 'virtualdevice'
[    1.057465] init: cannot find '/system/bin/livecap', disabling 'livecap'
[    1.063576] init: cannot find '/system/bin/virtualtouch', disabling 'virtualtouch'
[    1.160503] mdrv_software_ir: version magic 'SMP mod_unload ARMv7 ' should be '3.1.10 SMP preempt mod_unload ARMv7 '
[    1.396037] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    1.401368] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
shell@android:/ $ [    3.412358] ***** Create coredump file to /var/core_dump.960.gz ******
[    3.418647] * Ultimate CoreDump v0.4 : started dumping core into 'Coredump.960.gz' file *
[    3.426050] <1>##### elf aligned pages num : 3 + (3 Coredump guard buffers)
[    3.432856] ##### Not used first lower guard page, elf_foffset : 9264, aligned_elf_foffset : 12288
[    3.441070] ##### set_gzip_header() return success...
[    3.445743] ##### Allocated 267980 bytes for deflate workspace
[    3.451029] ##### coredump_alloc_workspaces() return success...
[    6.840905] ##### (vma->vm_next) == NULL ...
[    6.846156]  ##### Process addr space debug Info #####
[    6.850798]  ##### vma_cnt : 259
[    6.853704]  ##### vm_page : 1083
[    6.856724]  ##### user_page_cnt : 905
[    6.860115]  ##### zero_page_cnt : 178
[    6.863515]  ##### kernel_page_cnt : 0
[    6.866897] ##### uncomp_coredump_file_size : 4448256
[    6.871439] ##### GZIP tailer CRC32 : 2151096421
[    6.898833] CoreDump: finished dumping core
UART_115200
[AT][MB][start sb][0]
AC_ON
AutoDQS0-[456789ABCDE][56789ABCDE][3456789ABCD][3456789AB]-[0x7899]
AutoDQS1-[456789ABCDE][56789ABCDE][3456789ABCD][3456789ABC]-[0x7899]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][345]
U-Boot 2011.06-svn2626 (Dec 28 2013 - 11:28:28)
CPU  : Nike
Board: BD_MST049B_10AQV_NIKE
Hello U-Boot
DRAM:  458 MiB
SPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)
spi_init: cfg_env_offset: 0x1e0000, at 560
uboot held at [3b6ddf60~3ca00000]
Now running in RAM - U-Boot at: 3bb00000
MMC:    eMMC 3775MB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x0: 0x1a: 0x34: 0xc3:0x99: 0x40
It's the last cmd
msIR_Initialize
u8_Status ok:85..
Wait for PM51 standby...........PM51 APP build code time Aug 19 2013  20:06:32
Lib51 build code time Aug 19 2013  20:01:01
Hello Main
_MDrv_PM_PowerDown2Standby
[STR] Enter Refresh Mode
嫹稭缘∨荬?$JFR晧
发表于: 2017-12-19 09:37:47
这台机首先判断为灰屏引起故障,开机后检查LVDS各电压是否正常。如LVDS各电压均正常可以考虑重新写程序试试后再考虑(屏幕或主芯片故障)
发表于: 2017-12-19 10:05:06
主板坏了,屏坏的话不会自动关机的......
发表于: 2017-12-20 08:36:13
先刷数据看看,屏可能坏了
 楼主| 发表于: 2017-12-25 12:45:46
按大家的建议,刷机修复。
打印信息如下:
 楼主| 发表于: 2017-12-25 12:47:26
 楼主| 发表于: 2017-12-25 12:53:00
GMT+8, 2024-11-20 14:36 , Processed in 0.064171 sec., 9 queries .
