查看: 6664|回复: 12
康佳RTD2995方案清空EMMC后写引导+串口升级打印信息。
发表于: 2017-12-15 16:32:41
[INFO][src/rtk_boottable.cpp:rtk_mount_format_emmc():420]eMMC partition cache formating...
[INFO][src/rtk_common.cpp:rtk_command():235]Command:mke2fs -t ext4 /dev/block/mmcblk0p3 > /dev/null
BUS_TYPE = platform
mke2fs 1.42.6 (21-Sep-2012)
[INFO][src/rtk_boottable.cpp:rtk_mount_format_emmc():431]eMMC partition cache mounting...
[INFO][src/rtk_common.cpp:rtk_comma[  310.711743] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
nd():235]Command:rm -rf /cache;mkdir -p /cache
[INFO][src/rtk_common.cpp:rtk_command():235]Command:mount -t ext4 /dev/block/mmcblk0p3 /cache
[INFO][src/rtk_burn.cpp:rtk_extract_file():4062]
Extract rtd2995d/bootloader.tar file into /tmp/bootloader.tar...
[INFO][src/rtk_burn.cpp:rtk_extract_file():4064]tarfile_offset:0x00c0b800 (4945920 Bytes = 4830 KB)
[INFO][src/rtk_burn.cpp:rtk_extract_file():4090]extract rtd2995d/bootloader.tar from /mnt/udisk/sda1/install.img
100 |******************************| 4830 KB
[INFO][src/rtk_burn.cpp:rtk_extract_file():4110]extract ok
[LOG][src/rtk_common.cpp:rtk_find_file_in_dir():836]find vmlinux.rescue.magellan.bin.lzma in /tmp/bootloader
[INFO][src/rtk_burn.cpp:rtk_burn_bootcode_emmc():3450]
[Burn mmc boot part]
[INFO][src/rtk_burn.cpp:rtk_burn_bootcode_emmc():3454]
[Burn hwsetting]
100 |******************************| 14 KB
[INFO][src/rtk_common.cpp:rtk_file_verify():676]Verifying
[INFO][src/rtk_common.cpp:rtk_file_verify():709]Pass! total 15220 bytes checked
[INFO][src/rtk_burn.cpp:rtk_burn_bootcode_emmc():3488]
[Burn bootcode]
100 |******************************| 408 KB
[INFO][src/rtk_common.cpp:rtk_file_verify():709]Pass! total 418016 bytes checked
[INFO][src/rtk_burn.cpp:rtk_burn_bootcode_emmc():3542]
[Burn rescue]
100 |******************************| 4399 KB
[INFO][src/rtk_common.cpp:rtk_file_verify():709]Pass! total 4505312 bytes checked
[INFO][src/rtk_burn.cpp:rtk_burn_bootcode_emmc():3589]
[Burn extern_param]
[INFO][src/rtk_common.cpp:rtk_ptr_verify():748][Verifying]
100 |******************************| 0 KB
[INFO][src/rtk_common.cpp:rtk_ptr_verify():781]Pass! total 936 bytes checked
[INFO][src/rtk_tagflow.cpp:tagflow3_emmc():466]There is no USR_LOCAL_ETC partition
2995.rar
3.87 KB, 下载次数: 433, 下载积分: 金钱 -10
 楼主| 发表于: 2017-12-15 16:34:04
[INFO][src/rtk_burn.cpp:rtk_burn_img():954]
Burning linuxKernel filename(rtd2995d/vmlinux.develop.android.kk.rtd299x.tv035.emmc.bin) efwtype(0)...
[INFO][src/rtk_burn.cpp:rtk_burn_img():990]  flash_offset:0x02008000 (65600 sector) ~ flash_end:0x02d3b1ff (92632 sector) flash_allo_size:0x00d33200 bytes (27033 sector)
tarfile_offset:0x22bac400                       image_size:0x00d330f4 bytes (  13840628 Bytes =  13516 KB)
100 |******************************| 13516 KB
[INFO][src/rtk_common.cpp:fd_to_fd():190]checksum:0x4BDF2809
[INFO][src/rtk_common.cpp:rtk_file_verify():709]Pass! total 13840628 bytes checked
[INFO][src/rtk_burn.cpp:rtk_burn_img():1235]total time: 14 seconds
[INFO][src/rtk_burn.cpp:rtk_burn_img():1236]Complete!!
[INFO][src/rtk_tagflow.cpp:tagflow3_emmc():508]There is no ROOTFS partition
Burning audioKernel filename(rtd2995d/bluecore.audio) efwtype(1)...
[INFO][src/rtk_burn.cpp:rtk_burn_img():990]  flash_offset:0x02d3b200 (92633 sector) ~ flash_end:0x02f975ff (97466 sector) flash_allo_size:0x0025c400 bytes (4834 sector)
tarfile_offset:0x01179c00                       image_size:0x0025c2d0 bytes (   2474704 Bytes =   2416 KB)
100 |******************************| 2416 KB
[INFO][src/rtk_common.cpp:fd_to_fd():190]checksum:0x0B5232B9
[INFO][src/rtk_common.cpp:rtk_file_verify():709]Pass! total 2474704 bytes checked
[INFO][src/rtk_burn.cpp:rtk_burn_img():1235]total time: 3 seconds
Burning videoKernel filename(rtd2995d/video_firmware.bin) efwtype(2)...
[INFO][src/rtk_burn.cpp:rtk_burn_img():990]  flash_offset:0x02f97600 (97467 sector) ~ flash_end:0x03258dff (103110 sector) flash_allo_size:0x002c1800 bytes (5644 sector)
tarfile_offset:0x00941200                       image_size:0x002c17b8 bytes (   2889656 Bytes =   2821 KB)
100 |******************************| 2821 KB
[INFO][src/rtk_common.cpp:fd_to_fd():190]checksum:0x09136CBA
[INFO][src/rtk_common.cpp:rtk_file_verify():709]Pass! total 2889656 bytes checked
Burning video2Kernel filename(rtd2995d/video2_firmware.bin) efwtype(3)...
[INFO][src/rtk_burn.cpp:rtk_burn_img():990]  flash_offset:0x03258e00 (103111 sector) ~ flash_end:0x0330cdff (104550 sector) flash_allo_size:0x000b4000 bytes (1440 sector)
tarfile_offset:0x013dfe00                       image_size:0x000b3e54 bytes (    736852 Bytes =    719 KB)
100 |******************************| 719 KB
[INFO][src/rtk_common.cpp:fd_to_fd():190]checksum:0x0277092D
[INFO][src/rtk_common.cpp:rtk_file_verify():709]Pass! total 736852 bytes checked
[INFO][src/rtk_burn.cpp:rtk_burn_img():1235]total time: 1 seconds
Burning ecpuKernel filename(rtd2995d/ecpu.bin) efwtype(4)...
[INFO][src/rtk_burn.cpp:rtk_burn_img():990]  flash_offset:0x0330ce00 (104551 sector) ~ flash_end:0x0330f3ff (104569 sector) flash_allo_size:0x00002600 bytes (19 sector)
tarfile_offset:0x22ba9c00                       image_size:0x00002492 bytes (      9362 Bytes =      9 KB)
100 |******************************| 9 KB
[INFO][src/rtk_common.cpp:fd_to_fd():190]checksum:0x000F95F1
发表于: 2017-12-15 20:02:01
谢谢楼主的无私分享,论坛有你更精彩......
发表于: 2017-12-15 21:02:24
谢谢楼主,辛苦啦!!!
发表于: 2018-10-22 20:41:07
想问下清空EMMC指令怎么操作?
发表于: 2018-11-9 09:26:55
看不懂,能不能解释一下。
发表于: 2021-11-13 17:13:19
楼主也不说明是打印信息文件
发表于: 2022-10-14 15:08:42
涟水河 2018-10-22 20:41
想问下清空EMMC指令怎么操作?
擦除,擦空之前要查看EMMC硬件容量,首先按住电脑键盘ESC键不松,主板上电,进入控制台,EMMC为4G的擦空命令如下:
mmc erase blk 409612
EMMC为16G的命令如下:
mmc erase 0 0xe90000
GMT+8, 2024-12-19 15:04 , Processed in 0.060306 sec., 12 queries .
