查看: 2372|回复: 1
TCL L32E5300D DAYIN数据是什么意思
发表于: 2017-12-7 22:37:06
夿IST OK
BIST OK
ALL BIST OK!!
[23456789][3456789A][23456789A][456789ABC] 5668
[][][][] 0077
HAL_MIU_INIT2
Hello PM51...
Hello Main
MDrv_BDMA_Init OK..
bdma start .......
wait done.......
Bdma is done!
run code in dram
Start to reset MIPS
End of MIPS init
HAL_MB_Unmask_Cpu3_2_Cpu0
UART_115200__D
U-Boot 2011.06-svn14845 (Sep 03 2013 - 20:39:58)
CPU  : AMBER3
Board: BD_MS801_MAA2XG
DRAM:  256 MiB
SPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 2097152
        u32SecNum      = 32
        u32SecSize     = 65536
spi_init: cfg_env_offset: 0x1e0000, at 552
MMC:   mstar-emmc: 0, 0 blocks
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
read_spi_dbtable success...>>>
read table >>>
logo  offset[0x00180028] size[0x0001c2e1] end[0x0019c309]
music offset[0x0019c309] size[0x00000000] end[0x0019c309]
panel offset[0x0019c309] size[0x0000005c] end[0x0019c365]
ursa  offset[0x0019c365] size[0x00000024] end[0x0019c389]
keypad  offset[0x0019c389] size[0x00005000] end[0x001a1389]
db_checksum =:0x4ea5900e
save db_checksum =:0x4ea5900e
db_table.keypad_offset =:0x19c389...db_table.keypad_size=:0x5000
Read_PanelParaFromSpiflash success...>>>
UART BUS OFF!!_MApi_PM_ProcessPmInit >> MDrv_PM_Init
avlink_init done
power down
enable WDT
HAL_PM_WakeupFromZero
Run code in SPI.......?
请教一下TCL  L32E5300D DAYIN数据是什么意思
发表于: 2017-12-8 11:32:35
开机打印信息,也就是彩电内部CPU程序的运行状态,这些内容可以快速判断出主板的故障范围。
GMT+8, 2024-11-20 22:22 , Processed in 0.057884 sec., 9 queries .
