查看: 3900|回复: 4
请大师们帮我看看这个打印信息
发表于: 2017-10-22 13:42:42
J
Hello world!{m3a} svn-r(Mar 16 2015 15:57:38)
init_hwsetting_c
pre_hwsetting_c
post_hwsetting_c
parse hw setting DONE!
internal rom
force emmc
Normal boot
check boot media...
mmc_init...
emmc:read sys info
mmc_read_sysinfo . read sys info@emmc OK
HW: 0x00000ba0
AC: 0x00003de0
UB: 0x0004f3c8
EXT : 0x00002100
 ext fw RSA signature verify OK!
emmc:read uboot
 bootcode RSA signature verify OK!
GO
U-Boot 2012.07-TCL_ODM_Rtd2969_20150706/trunk/Rtd2969_ALI_QingJi/bootcode-svn931 (Dec 30 2015 - 14:38:26)
RTC: Init...Running
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A17
[krsv] use default uboot memory:
bank[0] Start = 0x0, Size = 0x20000000
DRAM:  512 MiB
Watchdog: Enabled
IO Config 2= PIN_WIFI_CTR@0000000100014603
IO Config 2= PIN_BL_ON_OFF@0000000001010804
IO Config 2= PIN_BL_ADJ@00ffff9600800108
IO Config 2= PIN_LVDS_ON_OFF@0000000000010004
IO Config 2= PIN_KEYPAD_MENU@0000000a1e000701
IO Config 2= PIN_KEYPAD_SOURCE@0000000a00000601
IO Config 2= PIN_KEYPAD_RIGHT@0000000a5c000601
IO Config 2= PIN_KEYPAD_LEFT@0000000a3f000701
IO Config 2= PIN_KEYPAD_UP@0000000a1e000601
IO Config 2= PIN_KEYPAD_DOWN@0000000a3f000601
IO Config 2= PIN_KEYPAD_PWR@0000000a00000701
IO Config 2= PIN_HDMI1_HOTPLUG@0000000001010404
IO Config 2= PIN_HDMI2_HOTPLUG@0000000001010504
IO Config 2= PIN_HDMI3_HOTPLUG@0000000000000000
IO Config 2= PIN_FLASH_WP@0000000000014703
IO Config 2= PIN_HDMI_MHL_SELECT@0000000100012804
IO Config 2= PIN_MHL_CABLE_DETECT@0000000000000904
IO Config 2= PIN_HP_OUT_JD@0000000000004b03
IO Config 2= PIN_AMP_MUTE@0000000100010c04
IO Config 2= PIN_POWER_DETECT@0000000000002504
IO Config 2= PIN_POWER_EN@0000000100010b04
IO Config 2= PIN_LED_G@0000000100010604
IO Config 2= PIN_LED_R@0000000101010704
IO Config 2= PIN_LVDS_SEL@0000000000014303
IO Config 2= PIN_HDMI1_DETECT@0000000000004503
IO Config 2= PIN_HDMI2_DETECT@0000000000004403
Board: TCL tv030 Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
To setup mmu...
MMC:   MMC: NOT allocate buffer from non-cache area
emmc:mmc_initial(1) Dec 30 2015 14:39:48
Release SPI Pad !!!
HW Reset eMMC
reset finish...
RTD294x eMMC: 0
Release SPI Pad !!!
RCA= 0x0
mmc:mmccr_set_bits_width(324) bus width switch to 8bits
emmc: clk change to 50MHz
mmccr_set_clk: 0x18000204=0x08601001
RCA= 0x0
Device: RTD294x eMMC
Manufacturer ID: fe
OEM: 14e
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.5 GiB
Bus Width: 8-bit
Factory: MMC
Factory: seq:0x3ef, blk:0xe000(pp:1), size:0x275000 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=1
BOOT_FAC_POWER_ON_MODE=1
BOOT_FAC_LVDA_MAP_MODE=1
BOOT_FAC_LVDS_PORT_MODE=1
BOOT_FAC_LVDS_BIT_MODE=1
BOOT_FAC_LVDS_MIRROR_MODE=0
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_TV_SYSTEM=1
IMGFILE_PATTERN not found
[bootparam.c 291]:can't IMGFILE_PATTERN
-------TALENT----->>>>>>boot_ac_on=1
-------TALENT----->>>>>>boot_fac_power_on_mode=1
boot_power_on_mode=1
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
Factory_RO: MMC
[FAC_RO] No factory_ro data in eMMC
[ENV] read_env from factory failed
[ENV] Using default environment variables
mac_len:27
mac_ptr:ethaddr a0.bb.3e.d7.ca.d7
msg:a0:bb:3e:d7:ca:d7
Mac Address use a0:bb:3e:d7:ca:d7 in factory
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: P7_K550WD7-LA350
panel_init_1st
CRT reg1=0,reg2=0
##### drvif_clock_set_dclk : 149000000 ###########
Panel: ulFreq:149000000, nDPLL:157499520, Mcode:35, Ncode:3, offset:6e9
dclk_sel = 1
=== Panel Type : 0 ===
liquan:panel.c,1318,panel_interface_common boot_fac_lvds_map_mode =1
0860:88000000, 0864:0, 0868:88000000, 086c:0
DISPI: BISR testing ....
DISPI: Finish BISR testing done
DISPD: BISR testing ....
DISPD: Finish BISR testing done
=== Panel Index : 0 ===
panel_init_2nd
GDMA module_init finish
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: fuse ready = a0000002
rtl8139: link status = 0000ffff
rtl8139: REALTEK RTL8139 @0xb8016800
Hit Esc or Tab key to enter console mode or rescue linux:  0 name=PIN_KEYPAD_PWR ppcb_enum.Name=PIN_KEYPAD_PWR, ppcb_enum.info=a00000701
Start Boot Setup ...
         FW Table to 0x0a820000, size=0x00000200 (0x0a820200)
         FW Table fr 0x02000000, fw count: 4
Normal boot fw follow...
Linux Kernel:
         FW Image to 0x00108000, size=0x01009fc8 (0x01111fc8)
         FW Image fr 0x02008000 (non-lzma)
Audio FW:
         FW Image to 0x81700000, size=0x0027bb28 (0x8197bb28)
         FW Image fr 0x03012000 (non-lzma)
Video FW 1:
         FW Image to 0x81a00000, size=0x002e9e90 (0x81ce9e90)
         FW Image fr 0x0328dc00 (non-lzma)
Video[image] data 1:
         FW Image to 0x86700000, size=0x0000b891 (0x8670b891)
         FW Image fr 0x03577c00 (non-lzma)
         found tmp/factory/bootfile.image, load it to 0x86700000
         BOOT: Use Factory LOGO file in tmp/factory/bootfile.image size=144054
Hold HW semaphore
Await bypass unmute
ACPU: BISR testing ....
ACPU: Finish BISR testing done
Release HW semaphore
Ago bf [SB2_INSTAT] =  0x00000000
af [SB2_INSTAT] =  0x00000000
Audio Version = 1010377 (+3ruhtracam)
SHA-1: 7a856e3
Common Version = 852433
Binary src compiled at Sep  2 2015 21:09:48
Note = SQA_DailyBuild
HDMI Raw Enable: MPG AC3 DTS MPEG2 AAC DDP WMAPRO MLP
SPDIF Raw Enable: MPG AC3 DTS MPEG2 AAC DDP WMAPRO MLP
Force 2ch Format: DTS DTSHD AC3 DDP MLP AAC WMAPRO
set global  0x00000000  0x0000bb80
set global  0x00000001  0x0000bb80
set global  0x00000002  0x0000bb80
set global  0x00000003  0x0000bb80
set global  0x00000004  0x0000bb80
set global  0x00000005  0x0000bb80
set global  0x00000006 H o0lxd0 0H0W0 bsbe8m0a p
h
osreet
glEonbaabll e  0VxC0P0U010
0
Vwait
00
7VC P U0x: 00BI0S0bR bt80es t
ing ....
[BOOTV_ACPIUO]:  Fshinarisehd- BmIemSR    te=s  ti0xnag 00do0n10e
0
0
[ReBlOOeaTs_Ae IHO]W  smaemgiapch_noruem  a g  ai=n
0V1go x00000000
[BOOT_ARIOo]s SvtearrstiToans_kcoCrdeea =te H o0xok0 030008000
0
i[niBtO OaTl_lA IDOC]U  Eirdrxor!
~mraegsiucm_en upmtbse r  0=x 0 000x00000000000
00V
0
pktQ  0x81cadb50, sz 8 16 8
V0 pktQ  0x00000000  0x00000000
_rk set disable
[VO]SynGen= 0x93010001
[vo] VSYNCGEN  0xd0000002/ 0x8006ddd0/ 0x93010001
[vo] Vodma(0) disable
[vo] VODMA(0) ForceBG(0)
发表于: 2017-10-22 14:55:09
看不出什么,应该有开机画面了。
 楼主| 发表于: 2017-10-23 18:53:21
鑫达家电 发表于 2017-10-22 14:55
看不出什么,应该有开机画面了。
卡在开机,升级无反应
发表于: 2017-10-24 21:28:45
先刷引导,再u盘升级.
 楼主| 发表于: 2017-11-1 22:22:18
鑫达家电 发表于 2017-10-24 21:28
先刷引导,再u盘升级.
没有软件00000000000000000
GMT+8, 2024-11-26 11:32 , Processed in 0.058709 sec., 9 queries .
