查看: 3399|回复: 1
8A13创维酷开42K1Y打印信息 正常开机的
发表于: 2017-9-17 15:40:09
EEEE I3000000032940xf3001100?
PGSR0: 0x80000fff
PGSR1: 0x00000000
DDR clock is 672MHz with 2T mode
Stage 00 Result 00000000
Stage 01 Result 00000000
Stage 02 Result 00000000
Stage 03 Result 00000000
HHH
cache enable
Boot From SDIO C
0x000000c7
ucl decompress
decompress true
0x12345678
Boot from internal device 1st SDIO C
System Started
spl boot time(us):0x0002e1b9
AML(m6tv_coocaa_v1@next) (Sep 27 2013 - 18:28:11)
Clear HDMI KSV RAM
DRAM:  1 GiB
relocation Offset is: 10624000
from sys start to board_init_r time(-us):5943733
IR init done!
register usb cfg[0] = 9fe89678
register usb cfg[2] = 9fe8a908
MMC:   SDIO Port B: 0, SDIO Port C: 1
LCD Initialize:
_lcd_module_enable---.
pll_sel=0, pll_div_sel=1, vclk_sel=0, pll_reg=0x40050c82, div_reg=0x10803, xd=1.
LCD:        1920x1080 32bbp
from board_init_r to start main_loop time(us):1667975
init suspend firmware done. (ret:0)
switch_boot_mode
mmcargs = setenv bootargs init=/init console=${console_debug} mem=1024m logo=osd0,loaded,panel mac=${ethaddr}
ethaddr = bc:83:a7:b9:cc:fe
suspend = off
console_debug = off
bootcmd = run emmcboot
bootfusb = off
Using default environment
vercurre = verafterdef
Device: SDIO Port C
Manufacturer ID: 0
OEM: 0
Name: Tran Speed: 25000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3959422976
Boot Part Size: 2097152
Bus Width: 4-bit
emmc save env ok
Unknown command 'setubootlogo' - try 'help'
MMC read: dev # 1, block # 16384, count 2048 ... 2048 blocks read: OK
Video initializing...
osd_layer_init
frame buffer address is 0x84100000
video size is 1920 X 1080
video bbp is 32
MMC read: dev # 1, block # 49152, count 16384 ... 16384 blocks read: OK
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-3.0.8+
   Image Type:   ARM Linux Kernel Image (lzo compressed)
   Data Size:    7196024 Bytes = 6.9 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
bootm start to prepare boot kernel time:368060us
from main_loop start to kernel decompress finished time:2785386us
machid from environment: 0x1124
EFUSE machid is not set.
Using machid 0x1124 from environment
Starting kernel ...
发表于: 2017-9-17 17:06:12
感谢分享
GMT+8, 2024-12-19 18:16 , Processed in 0.048821 sec., 10 queries .
