查看: 8577|回复: 11
论坛高手过来看看此山寨机打印信息
发表于: 2017-9-16 18:55:38
论坛高手过来看看此山寨机打印信息,求解读,谢了
     2017-9-16, 18:51:32
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
UART_115200
AC_ON
AutoDQS0-[456789ABCD][3456789ABCD][3456789ABCD][456789ABCDE]-[0x9888]
AutoDQS1-[3456789ABCDE][456789ABCDE][3456789ABCD][3456789ABCDE]-[0x8898]
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 03b00000
[AT][MB][start ub][344]
U-Boot 2011.06-00000-gc344e9f-dirty (Dec 17 2015 - 09:16:03)
cvte_buildinfo: c344e9f3_20151217_091550
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to Utopia
uboot held at [3e0ddf60~3f400000],size=013220a0
CPU  : Madison
Board: BD_MST066B_10AVX_14091_MADISON
DRAM:  500 MiB
Now running in RAM - U-Boot at: 3e500000
eMMC: DDR 48MHz
eMMC 3.63 GB [747FF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x0: 0x25: 0x92: 0xbb:0x3e: 0x79
[CPU INFO] cpu opencreate instance at 3e1d77a8 with private size 44 bytes at 3e1d77f0
[UTOPIA INFO] close moduleNames[38]: MODULE_CPU
msIR_Initialize
[AT][MBoot][Driver Init][679]
Changelist:        24543697
AC on
====cvte power on check usb and upgrade ====
<628> do_cvte_init_at_prama4env
Check USB port[0]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value ff:
1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
Check USB port[1]:
No USB is connecting
usb init failed
Check USB port[2]:
usb init failed
FAIL : can not init usb!!
<628> custar = -1
<628> USB Disk Not Found
<CVTE> do_cvte_get_mac_from_emmc
block_data[0]:00
block_data[1]:25
block_data[2]:92
block_data[3]:bb
block_data[4]:3e
block_data[5]:79
<628> Read MAC Value-->00:25:92:bb:3e:79
<628> EMMC MAC-->00:25:92:bb:3e:79 , ENV MAC-->00:25:92:bb:3e:79
<2984> do_cvte_init_at_env_by_value AT_Read=0 OR AT_B=0 OR AT_T=0 AT_BOOTCH=0:
Same as console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x1A200000 EMAC_MEM=0x40000 DRAM_LEN=0x40000000 LX_MEM2=0xA0000000,0x1A800000 cma_miu1=0xA0000000,0x10000000 KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=OFF
<628> AT Start UART Control-init_pram.AT_P=0
UART BUS OFF 1!!!
发表于: 2017-9-16 19:16:43
像是程序坏了,建议刷主程序
发表于: 2017-9-16 21:29:12
eMMC: DDR 48MHz
In:    serial
Out:   serial
Err    serial           eMMC 数据传输出错。
 楼主| 发表于: 2017-9-17 09:04:23
非常感谢楼上几位万忙之中给予回复,多谢了。
发表于: 2017-12-19 21:48:29 来自手机
我是新手,看不懂打印信息。
发表于: 2017-12-19 21:53:30
路过学习学习!!!!!
发表于: 2018-2-1 20:58:35 来自手机
看不懂这是什么
来自: 微社区
发表于: 2018-3-24 20:06:36
UART BUS OFF 1!!!
串口关闭吧
发表于: 2018-7-14 17:43:59
看不懂这是什么
GMT+8, 2025-12-15 12:56 , Processed in 0.057166 sec., 10 queries .
