查看: 2545|回复: 0
IZUMI LED Model: TLE15H400B
发表于: 2017-8-15 02:53:49
Chassis / Version: LA.MV6.D2
Panel: LP156WH2 (TL) (R2)
T-CON: LP156WH2-TLQ1 P / N: 6870S-0703F
Power Supply (PSU): adapter DC 12V, 4A
MainBoard: LA.MV6.D2 0343
MAINBOARD the IC: 25Q80BV, 24C32, YD1517P
TUNER: HFT-8F / 125CW
Brand: LG Display
Model: LP156WH2-TLR2 61 Compatible model
Type: a-Si TFT-LCD, Panel
Diagonal size: 15.6 inch
Resolution: 1366x768, WXGA
Display Mode: TN, Normally White, Transmissive
Active Area: 344.232x193.536 mm
Shape Style: Wedge (PCBA Bent, Depth? 5.2mm)
Surface: Antiglare
Brightness: 200 cd / m2
Contrast Ratio: 300: 1 (Min.)
Display Colors: 262K (6-bit)
Response Time: 16 (Tr + Td)
Frequency: 60Hz
Lamp Type: WLED Embedded (LED Driver)
Signal Interface: LVDS (1 ch, 6-bit), 40 pins
Voltage: 3.3V
GMT+8, 2024-11-26 08:17 , Processed in 0.050918 sec., 9 queries .
