查看: 3091|回复: 3
IZUMI Model: TL32H601B
发表于: 2017-8-15 02:51:46
Chassis / Version: MST6M181VS
Panel: LK315T3LA57
MainBoard: MST6M181VS-V4.0
IC MainBoard: CPU: MST6E181VS-LF-Z1, FLASH: EN25P32
Tuner: CDT-3BP512-36
Brand: SHARP
Model: LK315T3LA57
Type: a-Si TFT-LCD, Panel
Diagonal size: 31.5 inch
Resolution: 1366x768, WXGA
Display Mode: ASV, Normally Black, Transmissive
Active Area: 697.68x392.26 mm
Surface : Antiglare, Hard coating (2H)
Brightness: 500 cd / m2
Contrast Ratio: 2500: 1
Display Colors: 16.7M (8-bit)
Response Time: 7 (G to G)
Lamp Type: 10 pcs CCFL Embedded (Inverter)
Signal Interface: LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-8-19 10:03:25
楼主你是哪国的啊,一个汉字没有,你这分享的是这个主板的程序吗?
发表于: 2017-8-21 17:29:17
Thank you for sharing
发表于: 2017-8-21 20:42:42
谢谢您的分享
GMT+8, 2024-11-26 08:56 , Processed in 0.051411 sec., 9 queries .
