查看: 2960|回复: 1
SAMSUNG Model: LA32B350F1
发表于: 2017-8-12 02:09:17
Chassis / Version: G3F32CCN
Panel: LTF320AP06
T-CON: 320AP03C2LV0.2
Inverter (backlight): integrated into PSU
PWM Inverter: SEM2006
MOSFET Inverter: FDPF5N50UT
Trans Inverter: LT-LU32
Power Supply (PSU): BN44-00289B
PWM Power: FAN7530 (PFC), ICE3BR0665J
MOSFET Power: IPA60R600CP (PFC)
MainBoard: BN41-01199A BN94-03060A
IC MainBoard: CPU: SEMS03-LF; DRAM: K4T51163Q; EEPROM: AT24C256; SOUND: NTP-3200;
TUNER: BN40-00142B - TCPS3001PD11S (H)
Brand: SAMSUNG
Model: LTF320AP06
Type: a-Si TFT-LCD, Panel
Diagonal size: 31.5 inch
Resolution: 1366x768, WXGA
Display Mode: PVA, Normally Black, Transmissive
Active Area: 697.68x392.26 mm
Surface : Antiglare (Haze 7%), Hard coating (3H)
Brightness: 450 cd / m2
Contrast Ratio: 5000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
Response Time: 8 (G to G)
Frequency: 60Hz
Lamp Type: 4 pcs CCFL Without Driver
Signal Interface: LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-8-12 11:04:08
谢谢您的分享
GMT+8, 2024-11-18 05:56 , Processed in 0.056152 sec., 9 queries .
