查看: 4111|回复: 6
SONY Model: KDL-32BX320
发表于: 2017-8-5 03:26:18
SONY
Model: KDL-32BX320
Brand: AUO
Model: T315XW03 VE
Type: a-Si TFT-LCD, Panel
Diagonal size: 31.5 inch
Resolution: 1366x768, WXGA
Display Mode: MVA, Normally Black, Transmissive
Active Area: 697.685x392.256 mm
Surface: Antiglare (Haze 2%), Hard coating (3H)
Brightness: 400 cd / m2
Contrast Ratio: 3000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
Response Time: 6.5 (G to G)
Frequency : 60Hz
Lamp Type: 4 pcs CCFL Embedded (Inverter)
Signal Interface: LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
Chassis / Version: AZ2EK_P-2F
Panel: T315XW03 VE
T-CON: T315XW04 V1 31T10-T00
Inverter (backlight): T73I041.00 REV.0
PWM Inverter: OZ9966SN (24)
MOSFET Inverter: AO D4184 (3)
Trans Inverter: LT 136 A0843 005 1125V TT3-3
Power Supply (PSU): APS-283 G13 1-883-775-21
PWM Power: MIP2H2 (7), A3810M (24)
MOSFET Power: K5A50D
MainBoard: MT66_EU - S0100-2
IC MainBoard: MT5135AE, STA3698WS
Remote: RM-ED046
发表于: 2017-8-5 14:07:17
多谢程序分享。
发表于: 2017-8-6 19:04:19
我桥不东赢问
发表于: 2017-8-9 12:11:05
谢谢楼主的数据分享!
发表于: 2017-8-10 20:53:18
液晶电视修的少
发表于: 2017-8-10 22:08:53
怎么看都不像SONY风格~到底现在哪里代工的?
发表于: 2017-10-23 20:51:50
Thank you landlord data
GMT+8, 2024-12-19 23:16 , Processed in 0.056064 sec., 10 queries .
