查看: 2736|回复: 1
SONY Model: KDL-26U4000
发表于: 2017-8-5 03:12:35
SONY
Model: KDL-26U4000
Brand: SAMSUNG
Model: LTA260AP01
Type: a-Si TFT-LCD, Panel
Diagonal size: 26.0 inch
Resolution: 1366x768, WXGA
Display Mode: APVA, Normally Black, Transmissive
Active Area: 575.769x323.712 mm
Surface : Antiglare (Haze 14%), Hard coating (3H)
Brightness: 450 cd / m2
Contrast Ratio: 2000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
Response Time: 8 (G to G)
Frequency: 60Hz
Lamp Type: 5 pcs CCFL Embedded (Inverter)
Signal Interface: LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
GMT+8, 2024-12-19 21:49 , Processed in 0.052667 sec., 9 queries .
