查看: 2995|回复: 4
三洋42CE360LED不开机
发表于: 2017-8-3 15:14:30
三洋42CE360LED不开机
打印信息提示 bist-0 ERROR
测量发现 u27 ddr供电为4v
换1084adj为1084-2.5 开机成功 反复测试正常
正常打印如下GE_SetOnePixelMode
s8SN0(4E) s8SN1(4F)
g_u8DCOnOff = OFF
POWERON_MODE_OFF >>
should go to standby!!!!!
Power down
=> DeepSleep (0xFF) ?
  SPI BOOT
Console Initial OK
Maria10: BD_MST004B_20AVS_10306
MIU: DDR_400Mhz_2x
BIST_0 PASS.
07 07
[ 06 07 08 10 11 12 ]
[ 06 07 08 10 11 12 13 ]
08 10
MIU Initial OK
sar input test...
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
GE_SetOnePixelMode
s8SN0(4E) s8SN1(4F)
Memory is FBL mode
Disable Aeon
Disable Aeon Done
Init ITE 6633 OK
DSP code loaded successfully
========= CUS04_ATV_MM_M10 =========
DVB-T Software Version: 0.305665
[Board]: BD_MST004B_20AVS_10306
[Panel]: LG LC420EUN-SDV1
[Tuner]: HTF2_8C_116CW
[MEMORY_MAP]: MMAP_32MB
[DRAM SIZE]: 32 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 0
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[DISPLAY_LOGO]
=> DC_BOOT (1)
PM Wakeup by SAR
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
Memory is FBL mode
isp备份程序如下
主板图片如下
发表于: 2017-8-3 18:46:52
谢谢您的分享
发表于: 2017-8-3 22:13:24
Thank you for your sharing.I've saved this page for future need.
发表于: 2017-8-5 15:46:19
Thank you for sharing
发表于: 2017-8-7 15:22:15
谢谢楼主分享
GMT+8, 2024-11-18 01:30 , Processed in 0.066726 sec., 9 queries .
