查看: 8596|回复: 15
How to read and write memory OneNANDFlash KFG1GN6W2D
发表于: 2017-7-11 06:54:05
Hello, Team.
发表于: 2017-7-11 08:37:54
Please take a photo of the chip to show the chip type;or you can try to choose "NAND_AUTO" to read or write first.
 楼主| 发表于: 2017-7-11 10:17:07
Is it possible to read and write it by ISP without an adapter?
I have the adapter, but it got great for the memory chip.
This chip KFG1GN6W2D-HIB6 is 11x9 mm, I have only the 10.5 x 13mm ...
Do you have the bracket to screw on the smaller adapter?
 楼主| 发表于: 2017-7-11 10:18:08
 楼主| 发表于: 2017-7-11 10:23:25
This is the adapter I bought.
 楼主| 发表于: 2017-7-11 10:27:14
I need the 11x9mm adapter base suport.
Please check availability.
I'm a reseller here in Brazil.
Note the direction of the placement yo!  发表于 2017-7-11 10:32
发表于: 2017-7-13 22:12:33
Thanks for sharing
发表于: 2017-7-14 00:05:18
Thank you all for your posts.
发表于: 2017-10-2 05:30:14
Hi, could you solve the problem with the adapter? have you read/write KFG1GN6W2D with the adapter.
Does anyone knows if this memory could be read write via JTAG ISP?
Thanks in advance
发表于: 2017-10-3 16:05:22
KFG5616U1A
KFG1G16U2D
KFG1GN6W2D
KFM2GN6Q2B
KFM4G16Q4B
KFG1G16D2B
KFG8GH6U4M
GMT+8, 2024-12-23 18:58 , Processed in 0.061853 sec., 15 queries .
