创维26E61HR 8M40机芯 蓝灯不开机
这是故障机打印信息 SPI BOOT Console Initial OK Maria10: BD_MST004B_20AVS_10306 MIU: DDR_400Mhz_2x BIST_0 PASS. 07 07 [ 05 06 07 08 10 11 12 ] [ 05 06 07 08 10 11 12 ] 08 08
MIU Initial OK 故障机只到这里?
这是好板 正常时打印的信息 SPI BOOT Console Initial OK Maria10: BD_MST004B_20AVS_10306 MIU: DDR_400Mhz_2x BIST_0 PASS. 07 07 [ 05 06 07 08 10 11 12 ] [ 05 06 07 08 10 11 12 ] 08 08
MIU Initial OK [msKeypad_Init]: Allocated channel number > 2 !!!
sar input test... MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000 MDrv_PNL_Init u32PMRiuBaseAddr = A0000000 GE_SetOnePixelMode
==================== First GOP driver instance, flush GWIN HW ====================
s8SN0(D) s8SN1(E) MApp_DMP_InitDMPStat Disable Aeon
Disable Aeon Done
DSP code loaded successfully ===PowerOn_Music===
_GOP_GWIN_AlignChecker, This FB format needs to 4-pixels alignment !!!
==================================== ========= CUS04_ATV_MM_M10 =========
DVB-T Software Version: 0.305665
[Board]: BD_MST004B_20AVS_10306
[Panel]: REL260V0_000A_HD
[MEMORY_MAP]: MMAP_32MB
[DRAM SIZE]: 32 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 0
[ENABLE_POWER_SAVING_DPMS]: 0
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
[ENABLE_POWERON_MUSIC] ==================================== |
