查看: 8366|回复: 7
阿里平台打印信息案例(MS928平台)
发表于: 2017-6-23 11:39:56
Bootrom start
Boot Media: eMMC
Starting fastboot ...        (启动fastboot)
System startup         (系统启动)
DDRTR Suc
Reg Version:    v1.2.5
Reg Time:       2016/3/3115:59:03
Reg Name:       hi3751v500_2layer_cpu1000_ddr1600_1024m_1024mch0_0000mch1_emmc.xlsm
Fastboot 3.3.0 (liweixin@FAE26) (Dec 21 2016 - 15:26:53)
Fastboot:      Version 3.3.0
Build Date:    Dec 21 2016, 15:27:19
CPU:           Hi3751v500
Boot Media:    eMMC
MMC:   Synopsys Mobile storage: 0      (Synopsys移动存储)
MMC/SD Card:
    MID:         0x000015
    OID:         0x0100
    PSN:         0x04a749e4
    DATA:        12/2016
    Chip Type:   MMC
    MMC Version: 5.0
    Timing:      HS
    Host Clk:    50000000Hz
    Host Div:    0
    Bus Width:   8bit
    Chip Size:   3909091328 Bytes (High Capacity)
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Boot Addr:   0
The DDR memory layout:                               (DDR内存布局)
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10c817a8  517.9 KiB
            data: 0x10c817a8 - 0x10d107b8  572 KiB
Boot Env on eMMC
    Env Offset:          0x00100000
    Env Size:            0x00010000
    Env Range:           0x00010000
SDK_VERSION: [HiDPTAndroidV200R001C00SPC115_20160509]
<CVET-AT> do_cvte_at_reset_env
<CVET-AT> bootargslen=324
same as mem=1024M selinux=0 console=ttyAMA0,115200 no_console_suspend
blkdevparts=mmcblk0:1M(fastboot),1M(bootargs),10M(recovery),2M(deviceinfo),8M
(baseparam),8M(panelparam),80M(logo),40M(kernel),20M(misc),1024M(system),40M(atv),10M
(factorydata),600M(cache),10M(bootmusic),10M(bootmusicsec),20M(uuid),-(userdata)
mmz=ddr,0,240M,240M
<Hisi> CatchPowerOnKey RemoteRest=0x00000000
<Hisi> CatchPowerOnKey KeypadRest=0x00000000
<Hisi> isNewOptionAT newOpATkey=0x00000000
<Hisi> Normal Start                   (正常开始检测。。。)
---- init v500 usb reg ----
val = 0x7c000!
usb2.0 port1 value = 0x1000!
<CVTE-AT> Get_Cvte_Burn_MAC Init
<CVTE-AT> flashhandle_mac=0xcc10268
<CVTE-AT> BlockSize=0x00080000
Get_Cvte_Burn_MAC checksum1=0xdc, checksum2=0xdc
Get_Cvte_Burn_MAC DataEare1=0xdc, DataEare2=0xdc
burn macshow=74:72:b0:01:17:76
burn macread=74:72:b0:01:17:76
no need burn to emmc
<CVTE-AT> Get_Cvte_Burn_MAC Finish
read ok mac:74:72:b0:01:17:76
<Hisi> is_cvte_kernelat_jump_usbstart
<Hisi> consume input = 0
<Hisi> Normal Start
<Hisi> is_cvte_atwb_jump_usbstart init_pram.AT_WB = 0
<CVTE> [do_cvte_boot_Aging_loop][LINE:8] Enter Boot AgingMode isAT_B_Mode:0
<CVTE> AgingMode AS System
<CVET-AT> is_agingmode_B2 init_pram.AT_B_2=0
<CVTE-AT> Get_Cvte_AT_B Init
<CVTE-AT> Get_Cvte_AT_B Flag=0
<Hisi> is_cvte_aingmode AT_AingMode = 0
Set CEC onetouchplay :0
BootMode = POWER OFF
BootMode = 1 ACDC = 1
will_enter_recovery = 0
boot_after_reboot = 0
Go to sleep
System suspend.
======== [MCU PARAM] ========               (MCU参数   如下:。。。)
SYSID: 0x19050201     系统ID
DBGMASK: 0x00000001
SUSPENDTYPE: 0x00000000
GPIO POWER KEY: 0x00000000
GPIO LEVEL: 0x00000000
TIMER WAKEUP: 0xFFFFFFFF         (定时器唤醒)
IRTYPE: 0x00000004
IR NUM: 0x00000006
IR KEY: 0x639CFF00
IR KEY: 0xFE019088
IR KEY: 0xE41B9088
IR KEY: 0xF00F9088
IR KEY: 0xF20D9088
IR KEY: 0xFF00BF00
LSADC ZERO: 0x000000FC
LSADC channel A enable
LSADC channel B enable
LSADC GLITCHSAMPLE: 0x00000005
LSADC TIMESCAN: 0x00000258
LSADC POWERKEY0: 0x00000000, 0x00000010
LSADC POWERKEY1: 0x000000FF, 0x000000FF
LSADC POWERKEY2: 0x000000FF, 0x000000FF
LSADC POWERKEY3: 0x000000FF, 0x000000FF
Auto wakeup flag: 0x00000000          (自动唤醒标志)
Light on                (开始 点亮)
HDMIRX HPD invert:0x00000006
lsadc:6bit,data_delta=8,enable deglitch,power down,continue scan
======== [MCU Init Ready] ========        (MCU初始化)
Power down ARM ===>  关闭ARM
Set MCU to 24MHz ===>将MCU设置为24MHz
Config bus core idle state ===>配置总线内核空闲状态
Test bus core state ===>测试总线内核状态
DDR_PowerCtrl:0
======== [ARM Power Down] ========ARM掉电
Wait for 2s ...       等待2秒
======== [Waiting for Powerkey] ========    (等待Powerkey 待机键触发)
==irRawLKey: 0xFF00BF00
==irRawHKey: 0x00000000
IR key: 0xFF00BF00
Power On!
======== [Wake up by IR] ========
======== [ARM Power On] ========
Reset HDMI
  Bootrom start
Boot Media: eMMC
System startup           系统启动。。。
DDRTR Suc
Reg Version:    v1.2.5
CPU:           Hi3751v500
Boot Media:    eMMC
MMC/SD Card:
    MID:         0x000015
    OID:         0x0100
    PSN:         0x04a749e4
    DATA:        12/2016
    Chip Type:   MMC
    MMC Version: 5.0
    Timing:      HS
    Host Div:    0
    Bus Width:   8bit
    Boot Addr:   0
Boot Env on eMMC
mmz=ddr,0,240M,240M
<Hisi> CatchPowerOnKey RemoteRest=0xff00bf00
<Hisi> Leave NewOption FacMode
<Hisi> Normal Start
val = 0x7c000!
<Hisi> Normal Start
Go to sleep
uart debug uart_flag = 0
[cl?
======== [MCU PARAM] ========   MCU参数
SYSID: 0x19050201
DBGMASK: 0x00000001
IRTYPE: 0x00000004
IR NUM: 0x00000006
IR KEY: 0x639CFF00
IR KEY: 0xFE019088
IR KEY: 0xE41B9088
IR KEY: 0xF00F9088
IR KEY: 0xF20D9088
IR KEY: 0xFF00BF00
Light on
Power down ARM ===>
DDR_PowerCtrl:0
Wait for 2s ...
本人英语水平差,只做关键词语解释,请多多包涵!!!!!!!!!!
阿里平台打印信息案例.rar
2.4 KB, 下载次数: 897, 下载积分: 金钱 -10
发表于: 2017-6-23 13:28:30
好经验,谢谢。
发表于: 2017-6-23 18:58:59
谢谢楼主分享  完全看不懂 实用性不是很大 不要一味的迷信它
发表于: 2017-6-27 16:25:11
Thank landlord to share.
发表于: 2017-12-15 20:28:25
好的东西必须支持一下!顶!让更多人看到!
发表于: 2019-3-9 17:09:46
thanks for sharing
发表于: 2019-9-26 10:25:09
楼主有没有搞错啊,这是海思Hi3751方案的打印信息吧,不是6A928的,是什么地方抄来的吧??
GMT+8, 2024-12-19 17:47 , Processed in 0.089026 sec., 13 queries .
