查看: 5616|回复: 15
Haier LED LE32M600
发表于: 2017-6-20 03:04:29
Chassis / the Version: MSTV2409-ZC01-01
Plesk Panel: LK315T3HB94 // ST3151A05-5
Backlight LED: LED315D10-ZC14-01 / 02/03 (D)
CON-T: MT3151A05-3-the XC-1, ST3151A05-5
Driver LED (backlight): integrated Into MAINBOARD
LED driver the PWM: AP3039AM-the G1
LED driver the MOSFET: MDD1951
Supply the Power (the PSU): integrated Into MAINBOARD
MAINBOARD: MSTV2409-ZC01-01
MAINBOARD the IC: the CPU: TSUMV59XUS, the SPI the Flash: MX25L3206E, the S-PT2308
Remote: IR: TV3215-ZC25-05 (A
Firmware the FLASH the SPI Haier LE32M600, the Main: MSTV2409-ZC01-01, Plesk Panel: LK315T3HB9
piercing the FLASH the SPI Haier LE32M600, the Main: MSTV2409-ZC01-01, Plesk Panel: V320BJ7-PE1
Brand: the SHARP
Model: LK315T3HB94
the Type: of Si-a the TFT-LCD, the CELL
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: ASV, Black Normally, Transmissive
the Active Area: 697.69x392.26 mm
the Surface : Antiglare, Hard coating (2H)
Glass Depth: 0.70 + 0.70 mm
Contrast Ratio: 5000: 1
Display Colors: 16.7M (8 bit-)
Response Time: 7 (G to G)
Frequency: 60Hz
Signal Interface: LVDS (1 ch , 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-6-20 06:28:26
谢谢楼主的分享资料
发表于: 2017-6-20 06:47:05 来自手机
谢谢楼主的分享
发表于: 2017-6-20 07:03:38
谢谢您的分享
发表于: 2017-6-20 07:32:57
谢谢楼主分享资料
发表于: 2017-6-20 08:04:46
感谢师傅,分享资料。
发表于: 2017-6-20 08:19:30
提示: 作者被禁止或删除 内容自动屏蔽
发表于: 2017-6-20 12:21:02
Thank you for sharing related data and firmware of Haier LCD.
发表于: 2017-6-20 12:24:08
感谢楼主分享
发表于: 2017-6-20 20:26:05
我"English"学的不好。
GMT+8, 2024-12-24 04:24 , Processed in 0.056668 sec., 9 queries .
