查看: 3768|回复: 6
Haier LED LE32B8000T
发表于: 2017-6-20 03:01:41
Chassis / the Version: MS308C1-ZC01-01
Plesk Panel: LSC320AN02-S01
Driver LED (backlight): integrated Into MAINBOARD
LED driver the PWM: AP3064, OB3350
LED driver the MOSFET: MDD1951
Supply the Power (the PSU): integrated Into MAINBOARD
The Power the PWM: OB2273 ( the PWM SOT23-6 )
MAINBOARD: MS308C1-ZC01-01
MAINBOARD the IC: the CPU: MSD308BEM, the SPI the Flash: GD25Q64, the SOUND: TPA1517
Tuner: TDA18275
Installed matrix (LED-panel) LSC320AN02-S01.
To power the LED backlight inverter used, combined with the main board MS308C1-ZC01-01, controlled by the PWM controller AP3064, OB3350. As power LED-driver elements used MDD1951 type keys.
It is combined with the power module and configured MainBoard scheme flyback converter AC / DC voltage using c OB2273 chips (PWM SOT23-6).
MainBoard - the main board (motherboard) is a module MS308C1-ZC01-01, with the use of CPU chip: MSD308BEM, SPI Flash: GD25Q64, SOUND: TPA1517 and others.
TDA18275 tuner provides reception of TV programs and the setting of the canals.
发表于: 2017-6-20 06:19:39
谢谢您的分享
发表于: 2017-6-20 07:02:04
谢谢您的分享
发表于: 2017-6-20 12:27:43
感谢楼主分享
发表于: 2017-6-23 08:56:56
谢谢         分享               ,
发表于: 2017-6-24 00:02:36
Thank you for sharing
发表于: 2017-6-26 08:31:18
谢谢您的分享
GMT+8, 2024-12-22 21:23 , Processed in 0.058518 sec., 9 queries .
