查看: 3861|回复: 4
Haier LED LE24M600F
发表于: 2017-6-20 02:57:50
Panel: M240HTN01.0
CON-T: 24M09-C01 M240HTN01.0 the CTRL the BD; AUO-12304, AAT11732, AAT1301
Driver LED (backlight): integrated Into MAINBOARD
LED driver the PWM: AP3039AM-the G1
LED driver the MOSFET: AO4468, MDD1951, MDD3754
Supply the Power (the PSU): integrated Into MAINBOARD
The Power the PWM: OB2273 ( the PWM SOT23-6 )
The Power the MOSFET: MDF4N65B
MAINBOARD: MSTV2409-ZC01-01
MainBoard IC: TSUMV59XUS, 25L3206E, RT7257EN, PT2308-S
The Remote: HTR-A18H
dditional technical information about the panel:
Brand: AUO
Model: M240HTN01.0
the Type: of Si-a the TFT-LCD, Plesk Panel
's Diagonal size bed: 24.0 inch
Resolution: 1920x1080, FHD
the Display-Mode: TN, Normally White, Transmissive
the Active Area: 531.36x298.89 mm
Surface: Antiglare, Hard coating (3H)
Brightness: 250 cd / m2
Contrast Ratio: 1000: 1
Display Colors: 16.7M (6 bit + Hi--FRC)
Response Time: 3.5 / 1.5 (Tr / Td)
Frequency: 60Hz
Type Lamp: 9S4P WLED Without Driver
Signal Interface: LVDS (2 ch, 8-bit), 30 pins
Voltage: 5.0V
发表于: 2017-6-20 06:20:30
谢谢您的分享
发表于: 2017-6-20 07:25:11
谢谢您的分享
发表于: 2017-6-20 12:25:23
感谢楼主分享
发表于: 2017-6-26 08:28:25
谢谢您的分享
GMT+8, 2024-12-22 21:32 , Processed in 0.052741 sec., 9 queries .
