查看: 3563|回复: 5
Haier LED LE24B8000F
发表于: 2017-6-20 02:54:50
Chassis / the Version: MS0V591-ZC01-01
Plesk Panel: M236HJJ-P02
Driver LED (backlight): integrated Into MAINBOARD
Supply the Power (the PSU): integrated Into MAINBOARD
MAINBOARD: MS0V591-ZC01-01
MAINBOARD the IC: TSUMV59XUS, 25Q32BSIG
Brand: CHIMEI INNOLUX
Model: P02-M236HJJ
the Type: of Si-a the TFT-LCD, the CELL
's Diagonal size bed: 23.6 inch
Resolution: 1920x1080, FHD
the Display-Mode: the Super the MVA, Black Normally, Transmissive
the Active Area: 521.28x293 mm .22
Surface: Antiglare (Haze 3%), Hard coating (3H)
Transmissivity: 4.6% (with Polarizer)
Contrast Ratio: 3000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
Response Time: 10 ( G to G)
Frequency: 60Hz
Signal Interface: LVDS (2 ch, 8-bit), 30 pins
Voltage: 5.0V
发表于: 2017-6-20 06:21:44
谢谢您的分享
发表于: 2017-6-20 07:24:10
谢谢您的分享
发表于: 2017-6-20 12:26:42
感谢楼主分享
发表于: 2017-6-21 14:55:42
虽然看不到英文但是楼主确实很厉害
发表于: 2017-6-26 20:22:20
谢谢楼主!
GMT+8, 2024-12-22 21:06 , Processed in 0.058335 sec., 9 queries .
