用户名  找回密码
查看: 3573|回复: 3
Haier Model: L32A8A the A1
发表于: 2017-6-20 02:37:37
Chassis / the Version: PY12026
Plesk Panel: T315XW01 V.5
CON-T: T260XW02 V2 AUO Ctrl-016K1
Inverter (backlight): 4H.V1448.291 / B1 Darfon
Inverter the PWM: OZ964SN
Inverter the MOSFET: P2804BDG
Supply Power (PSU): PSM210-417-R
The Power the PWM: L6562 , NCP1377B
MainBoard: PY12026-Q (V2.1)
MAINBOARD the IC: MST6151DA-LF, IS42S32200C1-6TL, LM2596S, LV1116N, TDA1554Q
Tuner: JS-6H1 / 111A25HR
The Remote: HYF-35G
dditional technical information about the panel:
Brand: AUO
Model: T315XW01 V5A
the Type: of Si-a the TFT-LCD, Plesk Panel
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: AMVA, Black Normally, Transmissive
the Active Area: 697.68x392.26 mm
Surface: Antiglare, Hard coating (3H)
Brightness: 500 cd / m2
Contrast Ratio: 1200: 1
Display Colors: 16.7M (8 bit-)
Response Time: 15/5 (Tr / Td); 8 (G to G)
Frequency: 60Hz
Lamp Type: Embedded CCFL (Inverter)
Signal Interface: LVDS (1 ch, 8-bit), 30 pins
Voltage: 5.0V
举报
发表于: 2017-6-20 23:40:45
Thank you for sharing
举报
发表于: 2017-6-26 08:32:24
谢谢您的分享
举报
GMT+8, 2025-1-9 12:55 , Processed in 0.052401 sec., 9 queries .
