查看: 3122|回复: 5
HAIER L24F6
发表于: 2017-6-20 02:35:07
Chassis / the Version: F6 RTD2674
Inverter (backlight): 471R1006 467-0101-23731G
Inverter the PWM: MPS1022
Inverter the MOSFET: ME12P04
Inverter Trans: 401-8322-27411G
Supply the Power (the PSU): 465-01A2-18001G
MAINBOARD: 471-01A2-T7601G 2010.04.12 REV: 03 MJ16-AAP231-01672 941-11T7-61401G
Tuner: F21CT-2DK-E
The Remote: RC-A03
Brand: the LG the Display
Model: LC320DXY the SHA1-
the Type: of Si-a the TFT-LCD, the CELL
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the IPS, Black Normally, Transmissive
the Active Area: 697.685x392. 256 mm
Surface: Antiglare (Haze 1%), Hard coating (3H)
Transmissivity: 6.32% (with Polarizer)
Contrast Ratio: 1200: 1
Display Colors: 16.7M (8 bit-)
Response Time: 8/10 (Tr / Td )
Frequency: 60Hz
Signal Interface: LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-6-20 13:08:35
谢谢楼主分享。
发表于: 2017-6-21 14:52:04
谢谢楼主谢谢楼主
发表于: 2017-6-21 14:53:29
我要下载看看
发表于: 2017-6-24 16:31:03
Thank you for sharing
发表于: 2017-6-26 02:27:32
我要下载看看,谢谢楼主
GMT+8, 2024-12-22 21:25 , Processed in 0.057281 sec., 9 queries .
