查看: 3353|回复: 2
HAIER Model L19C10A
发表于: 2017-6-20 02:32:43
Chassis / the Version: QCX0608026 SVA150 XG04TB
Plesk Panel: LTM190EX-L21
Inverter (backlight): XAD354LR
Inverter the PWM: MP1038EM
MOSFET Inverter: 4822 8 pin
Inverter Trans: 19LES X81-0626X
The Power the MOSFET: P10NK60ZFP
MAINBOARD the IC: TDA15021H / N1C00, SM5964, RTD2023B, TDA1517NE, MP1410ES
Tuner: TEDE9-2B4A
The Remote: VC532237
Brand: the SAMSUNG
Model: L21-LTM190EX
the Type: of Si-a the TFT-LCD, Plesk Panel
's Diagonal size bed: 19.0 inch
Resolution: 1280x1024, SXGA
the Display-Mode: TN, Normally White, Transmissive
the Active Area: 376.32x301.056 mm
Surface: Antiglare (Haze 25%), Hard coating (3H)
Brightness: 300 cd / m2
Contrast Ratio: 700: 1
Display Colors: 16.7M, CIE1931 72%
Response Time: 1.7 / 6.3 (Tr / Td)
Frequency: 60Hz
Lamp Type: 4 Without Driver CCFL pcs
Signal Interface: LVDS (2 ch, 8-bit), 30 pins
Voltage: 5.0V
发表于: 2017-6-20 12:35:08
Thank for sharing.
发表于: 2017-6-20 13:10:02
谢谢楼主分享。
GMT+8, 2024-12-22 21:28 , Processed in 0.056380 sec., 9 queries .
