查看: 2805|回复: 5
Akai LED Model LEA-22V21M
发表于: 2017-6-10 02:30:41
The Chassis / the Version: T.VST59.62
Plesk Panel: A215ED1DA3-1
Driver LED (backlight): HQ-LED60-1R5
Supply the Power (the PSU): the Adapter 12V
MAINBOARD: T.VST59.62
MAINBOARD the IC: the CPU: TSUMV59XU-Z1, the SPI the FLASH: GD25Q322, TDA-1517P, TPS54329 (the PWM the Step-down), BL8024 (the PWM the Step-down marker GG ..)
Tuner: the CDT-3NP5I1-10
发表于: 2017-6-11 23:58:40
Thank you for sharing
发表于: 2017-6-12 09:57:41
merci pour le partage et bon courage
发表于: 2017-6-13 08:10:15
发表于: 2017-6-13 08:57:33
谢谢您的分享
发表于: 2017-6-15 09:08:06
谢谢您的分享
GMT+8, 2024-11-26 06:25 , Processed in 0.054327 sec., 9 queries .
