楼主: 居然666
老师们 请指点指点 创维8H73 EMMC 读写
发表于: 2017-9-26 13:52:59
EMMC若是通过电感的再供电的,建议拆除了,不与前面连能。
发表于: 2018-6-21 19:47:46
刚入手809H,亲测可用正常读取.只是速度有些慢
发表于: 2018-7-15 22:28:11
thanks for sharing
发表于: 2018-11-18 11:52:38
发表于: 2018-11-18 13:39:26
Thank you for your post
发表于: 2018-12-13 12:52:33
网站有你更精彩。
发表于: 2018-12-20 23:56:00
Hi
Can you try to disconnect the CLK resistor going to the main Processor and connect to the one end that connects to the flash.
GMT+8, 2024-11-25 22:49 , Processed in 0.050394 sec., 9 queries .
