查看: 3226|回复: 5
通用板RDA8501
发表于: 2017-5-23 07:56:45
请问各位师傅通用板RDA8501怎样用809编程器读出。
 楼主| 发表于: 2017-5-23 08:00:54
附上图片板号看一下
发表于: 2017-10-28 15:11:50
输入8501后确认就可以了、刚试了
发表于: 2017-11-8 17:12:35
wcmcc 发表于 2017-10-28 15:11
输入8501后确认就可以了、刚试了
板号SKR.03 8501主芯片,AUTOISPA未识别芯片,怎么回事?打印信息也没有,是焊线还是插VGA接口?
发表于: 2018-3-14 19:43:42
输入8501后确认就可以了、刚试了
确实是这样,谢谢提醒。
发表于: 2018-9-16 20:29:57
[attach]198421[/attached
To read data through isp: 1- Click Enter chip printing & write RDA, Manufacture will display it , Partnumber will display two options RDA8501    & RDA8503. Since the one you want is highligthed (blue) go and select OK.
2- Select Parameter setting, a sub window opens then chose VGA:RXD/SDA-12 , TXD/SCL-15 on the listed items (2nd of the 5 listed options).
3- Serial port speed leave it on Baud rate is 115200E ( 1st item of the 4 listed options)
4-Select Save to exit the changes.
5-Select READ and power up the board within 3 seconds and your reading will be accomplished.
The attached rar has photos of the steps.
Thank your to the selfless effort of the RT809H designers and developers
GMT+8, 2024-11-18 09:36 , Processed in 0.056575 sec., 10 queries .
