查看: 3220|回复: 0
创维50V5 8H83机芯,反复重启打印信息分析一下
发表于: 2017-5-10 21:01:35
BootMode = 1 ACDC = 0
Get Child Lock from eep = 0
will_enter_recovery = 0
boot_after_reboot = 0
Go to sleep
in boot_suspend,POWERON_FLAG=1
reg is 1,not enter suspend
poweron_led
CUSTOM Func[HI_DRV_CUSTOM_BoardInit] Line[104] :Board Name is SKY3751LV500_5800_A8H6000_BOARD
enter M5 V5 QS1 pwmvalue
enter v 58e6000 panel 150508DISP0, YPbPR:[0, 0, 0]
DISP0, CVBS:3
DISP0:fmt:7, pixelfmt:9, offset:[28, 16, 28, 16], stAspectRatio:[2, 0, 0]
DISP0:srcdisp:1, virscreen:[3840, 2160], BGColor:[0, 0, 0], kinds of degree:[B:50, C:50, H:50, S:50]
DISP1, YPbPR:[1, 2, 0]
DISP1, CVBS:0
DISP1:fmt:7, pixelfmt:9, offset:[28, 16, 28, 16], stAspectRatio:[2, 0, 0]
DISP1:srcdisp:1, virscreen:[3840, 2160], BGColor:[0, 0, 0], kinds of degree:[B:50, C:50, H:50, S:50]
DISP0, CVBS:3
fs_mgr: check_fs(): mount(/dev/block/platform/hi_mci.1/by-name/atv,/atv,ext4)=0
fs_mgr: Running /sbin/e2fsck on /dev/block/platform/hi_mci.1/by-name/atv
init: fs_mgr_mount_all returned an error
init: /dev/hw_random not found
init: cannot find '/system/bin/rild', disabling 'ril-daemon'
healthd: No charger supplies found
healthd: BatteryStatusPath not found
healthd: BatteryHealthPath not found
healthd: BatteryPresentPath not found
healthd: BatteryCapacityPath not found
healthd: BatteryVoltagePath not found
BT_USB: major 250
init: property 'sys.powerIn   HDCP Connect port 2!
=======enloopPort =0 ========enState=0 :===========
lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
lowmemorykiller: oom_adj 0 => oom_score_adj 0
lowmemorykiller: oom_adj 1 => oom_score_adj 58
lowmemorykiller: oom_adj 2 => oom_score_adj 117
lowmemorykiller: oom_adj 3 => oom_score_adj 176
lowmemorykiller: oom_adj 9 => oom_score_adj 529
lowmemorykiller: oom_adj 15 => oom_score_adj 1000
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready           到这里就卡住不走了,然后再反复重复上的信息
GMT+8, 2024-11-27 22:19 , Processed in 0.053541 sec., 9 queries .
