楼主: hedong7655
刷写IT8586E成功后不能再次读写
发表于: 2017-8-6 10:45:55
我也是和你一样求解决
发表于: 2017-11-18 10:28:17
卧槽,我一直都以为是EC刷坏了.妹的,离线刷还有这毛病啊?
发表于: 2018-7-14 21:51:06
I have the same problem...
发表于: 2018-7-14 21:53:50
when I use offline. it returns the same the same problem.
however, when I program it Online then the read and write are working even if programming multiple times
发表于: 2018-7-14 22:58:33
But in order to make the online process working then you need to connect the 12v power supply to the programmer in addition to usb cable. because the 5v USB cable provide is not sufficient to power the chip correctly.
so make sure :
1- ground is connected to motherboard ground.
2- the 12v power supply is connect to the programmer as well as the USB cable off course.
3- choose the right keyboard pins in the software.
4- press read button and in only one second after pressing the read button connect the laptop power cable to the motherboard.
and you are ready to read and reprogram the chip as much as you want.
HOPE this helps
THANKS
 楼主| 发表于: 2018-7-16 11:56:36
weeelcup 发表于 2018-7-14 22:58
But in order to make the online process working then you need to connect the 12v power supply to the ...
Thank you very much
发表于: 2018-7-18 08:38:17
You are very welcome
发表于: 2018-12-27 15:50:19
12V to programmer will damage your programmer....我的已经烧掉了...别信
GMT+8, 2025-12-15 12:50 , Processed in 0.052795 sec., 10 queries .
