海信LED65k560j3d,打印信息,rsag7.820.4899(bom1)
下面是打开电源开关到红灯亮的打印信息
狟IST OK
BIST OK
ALL BIST OK!!
[3456789A][456789ABC][456789AB][56789AB] 6878
[0123456789ABCDEF][0123456789ABCDEF][456789A][456789ABC] 7778
HAL_MIU_INIT2
Hello PM51...
Hello Main
MDrv_BDMA_Init OK..
bdma start .......
wait done.......
Bdma is done!
run code in dram
Start to reset MIPS
End of MIPS init
HAL_MB_Unmask_Cpu3_2_Cpu0
UART_115200__D
U-Boot 2011.06 (Aug 20 2012 - 15:44:43)
CPU : AMBER3
Board: BD_MST029B_10AFVA
DRAM: 256 MiB
SPI: Flash is detected (0x0507, 0xC2, 0x20, 0x15)
MDrv_SERFLASH_GetInfo()
u32AccessWidth = 1
u32TotalSize = 2097152
u32SecNum = 32
u32SecSize = 65536
spi_init: cfg_env_offset: 0x1e0000, at 551
[msKeypad_Init]: Allocated channel number > 1 !!!
@@@@@@ u32CpuSpeedMHz= 1008 MHz
NAND: MBOOT UNFD-----------------------------------------------------------2011-10-25 15:45:25
----------------------------------DMA MODE------------------------------------------------
nand_unfd_init NC_ResetFCIE done
nand_unfd_init NC_ResetNandFlash done
NC_ReadIDID: EC D3 51 95 58 EC , total 6 bytes ID.
nand_unfd_init NC_ReadID done
>>>>>>ID=0xEC 0xD3 0x51 0x95
nand_unfd_init drvNAND_CHECK_FLASH_TYPE done
reg_ckg_fcie(1F201790)=0000005C
nand_unfd_initUNFD, WordMode:0
nand_unfd_init ECC_TYPE_4BIT
nand_unfd_init NC_Config done
1024 MiB
UART BUS OFF!!HAL_PM_DisablePmSleepInt
_MApi_PM_ProcessPmInit >> MDrv_PM_Init
@@MDRV_PM:IR List[00] = 0d
@@MDRV_PM:IR List[01] = 92
@@MDRV_PM:IR List[02] = ff
@@MDRV_PM:IR List[03] = ff
@@MDRV_PM:IR List[04] = ff
@@MDRV_PM:IR List[05] = ff
@@MDRV_PM:IR List[06] = ff
@@MDRV_PM:IR List[07] = ff
@@MDRV_PM:IR List2[00] = 0d
@@MDRV_PM:IR List2[01] = 92
@@MDRV_PM:IR List2[02] = ff
@@MDRV_PM:IR List2[03] = ff
@@MDRV_PM:IR List2[04] = ff
@@MDRV_PM:IR List2[05] = ff
@@MDRV_PM:IR List2[06] = ff
@@MDRV_PM:IR List2[07] = ff
HAL_PM_EnableWkEventIr
HAL_PM_EnableWkEventSAR
HAL_PM_DisableWkEventGPIO0
HAL_PM_DisableWkEventGPIO1
HAL_PM_DisableWkEventUart1
HAL_PM_DisableWkEventSync
HAL_PM_EnableWkEventRtc0
HAL_PM_EnableWkEventRtc1
HAL_PM_DisableWkEventDVI0
HAL_PM_DisableWkEventDVI3
HAL_PM_DisableWkEventCEC
avlink_init done
HAL_PM_DisableWkEventAvlink
HAL_PM_DisableWkEventIr
power down
enable WDT
HAL_PM_WakeupFromZero
PowerDownMode = 0
Run code in SPI.......
L3 Ideal = 1
cache = 1300
_MDrv_PM_PowerDown2Standby
?菧?﹢献盐属盏??
下面是按遥控开机键二次开机的打印信息
BIST OK
BIST OK
ALL BIST OK!!
HAL_MIU_INIT2
MDrv_BDMA_Init OK..
bdma start .......
wait done.......
Bdma is done!
run code in dram
Start to reset MIPS
End of MIPS init
bring up MIPS over
UART_115200__D
CPU : AMBER3
DRAM: 256 MiB
u32AccessWidth = 1
u32SecNum = 32
u32SecSize = 65536
1024 MiB
UART BUS OFF!!
