查看: 4024|回复: 2
NOR TSOP56 support
发表于: 2017-3-24 11:52:55
你好。我有兴趣购买这个程序员。但是我看不到需要读写的TSOP56 NOR芯片的任何支持。芯片是:
Spansion S29GL128P90TFIR2
Spansion S29GL128N90TFIR2
三星K8Q2815UQB-PI4B
三星K8P2716UZC-QI4D
这些都是128M NOR TSOP 56芯片。 RT809可以通过手动添加来读写这些吗?这些可以添加到软件中吗?
非常感谢您的帮助和协助。
发表于: 2017-3-24 18:33:26
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于: 2017-11-20 07:36:10
I would really like help with this.
Admin, can you please add support for the Samsung K8Q2815 TSOP-56 NOR chip?
Using the follow chips to program it doesn't work, the data is all wrong in the dump!
Spansion S29GL128P90TFIR2 -Ignore the error but data dump is garbled
Macronix MX29GL128ELT2I-90G - Ignore the error but data dump is garbled.
Can you PLEASE be fixed? This is a very popular NOR chip.
GMT+8, 2024-12-28 01:56 , Processed in 0.077908 sec., 10 queries .
