查看: 4733|回复: 6
SONY KDL-32EX401
发表于: 2017-3-12 03:52:04
Chassis / the Version: AZ1-the K
Plesk Panel: LTY320HM03
The CON-the T: FHD_MB4_C2LV1.6
Inverter (the backlight): SSI320_4UG01
Inverter the PWM: SSI091ASN (24pin)
Inverter the MOSFET: MDD1752
Power Supply (PSU): 147 420 812
MAINBOARD: 1-881-019-13
IC MainBoard: 56-F855E-1
Brand: the SAMSUNG
the Model: LTY320HM03
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 31.5 inch
Resolution: 1920x1080, FHD
the Display-Mode: the PVA, of Black Normally, Transmissive
the Active Area: 698.4x392.85 mm
the Surface : Antiglare (Haze 7%), the Hard coating (3H)
the Brightness: 400 the cd / m2
the Contrast the Ratio: 5000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 12/8 (Tr of / the Td) ; 8 (the G to the G)
the Frequency: 60Hz
the Lamp the Type: 4 Embedded the CCFL pcs (Inverter)
the Signal the Interface: the LVDS (2 ch, 8-bit), 51 pins
Voltage: 12.0V
发表于: 2017-3-12 04:49:15
提示: 作者被禁止或删除 内容自动屏蔽
发表于: 2017-3-12 08:27:27
谢谢你的分享
发表于: 2017-6-9 22:32:18
谢谢你的分享
发表于: 2017-6-19 08:43:52
谢谢你的分享
发表于: 2017-7-11 23:23:56
nice share buddy...
发表于: 2017-7-30 01:15:25
Thank you good information, classified collection download
GMT+8, 2024-12-19 21:57 , Processed in 0.060581 sec., 10 queries .
