查看: 2675|回复: 1
SONY Model: KDL-32P2530
发表于: 2017-3-12 03:34:47
The Chassis / the Version: the SE-1T
Plesk Panel: T315XW02 V.1
The CON-the T: T315XWO2 of V0
Inverter (the backlight): Darfon 4H.V0708.401 / the C
Inverter the PWM: OZ964SN
Inverter the MOSFET: P5504EDG NICOS
Inverter of Trans: 4002Y708006 (the GP) -03 4002Y652008 (the GP) -04
Supply Power (PSU): A-A-1189-415 G1
The Power the PWM: MCZ23001B (18H), SK751 (8N), STR-A6169 (8)
The Power the MOSFET: 2SK3469
MAINBOARD: a BDT 1-872-686-11 (A-1242-773-A), the A1 A-1189-407-A 1-870-677-13
MAINBOARD the IC: TDA9974AHS / 8/12, NEC D61123F1-100, TK11185CSCL-G, PQ1CY1032ZP
The Remote: the RM-ED007
Additional technical information about the panel: Brand: AUO Model: T315XW02 V1
Type: a-Si TFT-LCD, Panel Diagonal size: 31.5 inch Resolution: 1366x768, WXGA Display Mode: AMVA, Normally Black, Transmissive Active Area: 697.68x392.26 mm the Surface: Antiglare, the Hard coating (3H) the Brightness: 500 the cd / m2 the Contrast the Ratio: 1200: 1 Display Colors: 16.7M (8-bit), CIE1931 72% the Response Time The: 8 (the G to the G) the Frequency: 60Hz the Lamp the Type: Embedded the CCFL (Inverter) the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins Voltage: 5.0V
发表于: 2017-3-13 13:38:29
谢谢楼主的分享!
GMT+8, 2024-12-22 11:42 , Processed in 0.055136 sec., 9 queries .
