查看: 2878|回复: 1
SONY Mode KDL-32P2520
发表于: 2017-3-12 03:29:02
The Chassis / the Version: the SE-1
Plesk Panel: T315XW02 V.1.
The CON-the T: T315XO2 of V0, 05A30-1A
Inverter (the backlight): DARF 4H.V0708.401 6lamp DARFON 4H.V0708.401 / C
Inverter the PWM: OZ964SN
Inverter the MOSFET: P5504EDG NICOS
The Supply the Power (the PSU): A-1189-415-A CMKI the G1-81X
The Power the PWM: LM324DG, the LM393, MCZ3001DB (18), STR-A6169 (8)
The Power the MOSFET: 2SK3469
MAINBOARD: BDTR2, A-1242-773-A, p / the n 1-872-686-11
MAINBOARD the IC: UPD61123F1-100-KA3-A HY27US08281 EDD1216AATA-6B-the E
Additional technical information about the panel: Brand: AUO Model: T315XW02 V1
Type: a-Si TFT-LCD, Panel Diagonal size: 31.5 inch Resolution: 1366x768, WXGA Display Mode: AMVA, Normally Black, Transmissive Active Area: 697.68x392.26 mm the Surface: Antiglare, the Hard coating (3H) the Brightness: 500 the cd / m2 the Contrast the Ratio: 1200: 1 Display Colors: 16.7M (8-bit), CIE1931 72% the Response Time The: 8 (the G to the G) the Frequency: 60Hz the Lamp the Type: Embedded the CCFL (Inverter) the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins Voltage: 5.0V
发表于: 2017-3-12 08:20:05
谢谢你的分享
GMT+8, 2024-12-22 11:49 , Processed in 0.053912 sec., 9 queries .
