panel: the CY-GH040BGSR1V
main: the BN-94-08117L BN41-02098B
F59L1G81A
25Q40CLSIP
S24C256
K4B2G1646Q-BCKO
NTP7414
Tuner: BN40-00294A
the PCU: BN44-00703A L48S1_ESM
S3051
6N15287 second line 6A01
7014X
13N60M
AOD5N40 the X2
50R380P x2
the T -Con: RUNTK5538TP
KL5T3067
MAX9684A
ICL9860
Q40A-104G
The firmware archive: 25Q40CLSIP, S24C256.
There was a failure: it was not the voltage VGH. T-Con: RUNTK5538TP. Do not set the resistor, through which a stabilizer ICL9860 output, VGH voltage goes to the loop connector. Looked at photos on the internet, there is also no resistor : Upset:. Compared with T-Con: RUNTK 5351TP 0055FV all voltages are the same, put resistor 1 com. VGH 27 volts, the image was normal, television worked day and gave it to the client.
