查看: 3273|回复: 2
SHARP LED Model: LC-32LE530RU
发表于: 2017-3-10 11:24:53
The Chassis / the Version: 17MB61
Plesk Panel: LC320EUD (the SD) (the A2)
LED backlight: 2 * 40 Led (6V); 5 8 Chanal * Led * 62 mA
The CON-the T: 6870-0358A ver1.0 the V6 32/42/47 the FND 12Dz the P / of N; TL2433MC, TPS65194, TPS65168, MAX9668E, 432RP
Driver the LED (the backlight): 6917L-0045A PCLC-D002 A Rev0.7
The LED driver the PWM: SW5508, SM1202
The Supply the Power (the PSU): 17PW07-2
The Power the PWM: FAN7529 (the PFC), FAN7621 , FSDL321 (the Standby), NCP1579 (the Step-Down The)
The Power the MOSFET: FQPFN50C, A04842
MAINBOARD: 17MB61-3 v1
MAINBOARD the IC: W9751G6J8-18, 25L8006E, 25L1606E, the AC-NT5TU64M16GG the X2, MP1484EN, MAX9736A
Tuner: DTOS403LH122E
Brand: the LG the Display
the Model: LC320EUD-sda2
the Type: a-of Si the TFT-the LCD, Plesk Panel
's Diagonal size bed: 31.5 inch
Resolution: 1920x1080, FHD
the Display-Mode: the S-the IPS, Normally of Black, Transmissive
the Active Area: 698.4 mm x392.85
Surface: Antiglare (Haze 10%), Hard coating (3H)
Brightness: 450 cd / m2
Contrast Ratio: 1,600: 1
Display Colors: 16.7M / 1.06B (8-bit / 8-bit + Dithering), CIE1931 72%
Response Time: 5 (G to G); 8 (MPRT)
the Frequency: 120Hz + 120Hz
the Lamp the Type: Embedded WLED (the LED Driver)
the Signal the Interface: the LVDS (4 ch, 8/10-bit), 92 pins
Voltage: 12.0V
发表于: 2017-3-10 12:11:54
谢谢你的分享
发表于: 2017-3-13 01:38:23
下载来看看了
GMT+8, 2024-12-20 13:38 , Processed in 0.049665 sec., 9 queries .
