查看: 2083|回复: 2
LG Model: 26LK330
发表于: 2017-3-10 03:08:22
The Chassis / the Version: LA01U
Plesk Panel: T260XW04 V.9
The CON-the T: 31T1Q0-T00 T315XW04 the V1
Inverter (the backlight): VIT71886.00 the REV: 2LOGAH
The Supply the Power (the PSU): EAX63985401 / 5 LGP26-11P
The Power the PWM: L6599AD (the PWM Resonant), 3BR4765JZ (the Standby)
MAINBOARD: EAX64113202 (0)
MAINBOARD the IC: the CPU: the RP-LGE107DC, of DDR: H5TQ1G63DFR-the PBC, Nand the: K9F1G08U0D, the FLASH 25Q80
Tuner: TDTJ-S001D EBL60721201
Brand: AUO
the Model: V9 T260XW04
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 26.0 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the MVA, of Black Normally, Transmissive
the Active Area: 575.769x323.712 mm
Surface: Antiglare (Haze 2%), the Hard coating (3H)
the Brightness: 450 the cd / m2
the Contrast the Ratio: 3000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 6.5 (the G to the G)
the Frequency : 60Hz
the Lamp the Type: 4 Embedded the CCFL pcs (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
 楼主| 发表于: 2017-3-10 03:11:50
LG Model: 26LK330
发表于: 2017-3-10 07:45:01
我要试试看,谢谢
GMT+8, 2024-12-28 02:22 , Processed in 0.051608 sec., 9 queries .
