查看: 2003|回复: 0
SAMSUNG Model: LE19R71B
发表于: 2017-3-10 03:00:28
The Chassis / the Version: GBE19SE
Plesk Panel: M190A1-L02 RevC2
Inverter (the backlight): the SIP-W19A
Inverter the PWM: FAN7311 (20)
Inverter the MOSFET: 4525GEM
Inverter of Trans: TMS90631CT
The Supply the Power (the PSU): the SIP-W19A
The Power the PWM: DM0465R
MAINBOARD: BORDEAUX19
Brand: the CMO
the Model: M190A1-L02
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 19.0 inch
Resolution: 1440x900, a WXGA +
the Display-Mode: the TN, Normally the White, Transmissive
the Active Area: 410.4x256.5 mm
Surface: Antiglare (Haze 25%), Hard coating (3H)
Brightness: 300 cd / m2
Contrast Ratio: 850: 1
Display Colors: 16.2M (6 + FRC bit-)
Response Time: 1.5 / 3.5 (Tr / Td)
the Frequency: 60Hz
the Lamp the Type: 4 Driver Without the CCFL pcs
the Signal the Interface: the LVDS (2 ch, 8-bit), 30 pins
Voltage: 5.0V
GMT+8, 2024-11-18 06:43 , Processed in 0.053942 sec., 9 queries .
