查看: 2792|回复: 3
SAMSUNG Model: LA32A330 LA32A330J1N
发表于: 2017-3-10 02:38:19
The Chassis / the Version: N61A
Plesk Panel: LTF320AP01
The Supply the Power (the PSU): BN44-00191B
The Power the PWM: FAN7530 (the PFC), MC33067P (the PWM 16, the pin), FSQ0165RN (the Standby)
The Power the MOSFET: 11N60 (the PFC), FQPF9N50CF
MAINBOARD: BN41-00984A
MAINBOARD the IC: SEMS01, MX25L1605A, 24C256
Brand: the SAMSUNG
the Model: LTF320AP01
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the PVA, of Black Normally, Transmissive
the Active Area: 697.68x392.26 mm
the Surface : Antiglare (Haze 14%), the Hard coating (3H)
the Brightness: 450 the cd / m2
the Contrast the Ratio: 3000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 8 (the G to the G)
the Frequency: 60Hz
the Lamp the Type: Embedded the CCFL 12 pcs (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-3-10 07:30:23
谢谢你的分享
发表于: 2017-5-4 00:15:21
谢谢你的分享
发表于: 2017-5-9 11:59:35
谢谢你的分享
GMT+8, 2024-12-20 09:19 , Processed in 0.052343 sec., 9 queries .
