查看: 2283|回复: 2
SAMSUNG Model: 37A330J1
发表于: 2017-3-10 02:34:05
The Chassis / the Version: GJE37SE
Plesk Panel: T370XW02 the VC
The CON-the T: 37T03-C01 (the F of Gamma-AS15)
The Supply the Power (the PSU): BN44-00220A
The Power the PWM: TDA4863G (the PFC), STR-A6159 (the Standby), MC33067P (the PWM 16pin)
The Power the MOSFET: FCPF20N60S, FQPF9N50C
MAINBOARD: BN41-00982A BN94-01759U
MAINBOARD the IC: the CPU: SAMS01; DRAM: EM6A9160TSOA-5G; SPI Flash: MX25L1605AM2I-12G; EEPROM: 24C256;
Tuner: BN40-00116A HTM2-6L2 / 235S
Brand: AUO
the Model: VC02 T370XW02
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 37 inch
Resolution: 1366x768, a WXGA
the Display-Mode: AMVA, of Black Normally, Transmissive
the Active Area: 819.6x460.8 mm
Surface: Antiglare (Haze 11%), the Hard coating (3H)
the Brightness: 450 the cd / m2
the Contrast the Ratio: 3000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 6.5 (the G to the G)
the Frequency : 60Hz
the Lamp the Type: Embedded the CCFL (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-3-10 07:32:58
谢谢你的分享
发表于: 2017-3-10 07:34:15
谢谢你的分享
GMT+8, 2024-11-18 06:48 , Processed in 0.054098 sec., 9 queries .
