查看: 2227|回复: 2
FUSION LED Model: FLTV-D22H11
发表于: 2017-3-10 02:16:28
he Chassis / the Version: T.MS6M181.7A 11203
Plesk Panel: LQ215M1LGN2
MAINBOARD: T.MS6M181.7A 11203
MAINBOARD the IC: the CPU: the LF-MST6E181VS-the Z1; SPI Flash: 25Q32SIP;
Tuner: AFT7 / W1306
Brand: the SHARP
the Model: LQ215M1LGN2
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 21.5 inch
Resolution: 1920x1080, FHD
the Display-Mode: the TN, Normally the White, Transmissive
the Active Area: 476.64x268.11 mm
the Surface : Antiglare (Haze 25%), the Hard coating (3H)
the Brightness: 300 the cd / m2
the Contrast the Ratio: 1000: 1
Display Colors: 16.7M (8 bit-)
the Response Time The: 1.5 / 3.5 (Tr of / the Td)
the Frequency: 60Hz
the Lamp the Type: 11S3Px3x2CN WLED Driver Without
the Signal the Interface: the LVDS (2 ch, 8-bit), 30 pins
Voltage: 5.0V
发表于: 2017-3-10 07:43:41
谢谢你的分享
GMT+8, 2024-11-26 02:23 , Processed in 0.060579 sec., 9 queries .
