The Chassis / the Version: CV9202H-TPW
Plesk Panel: ST3151A04-1 / Ver.2.4
MAINBOARD: CV9202H-TPW
MAINBOARD the IC: the SPI the Flash: 25Q64BV;
Tuner: ST03WS-2A-the E
Brand: CSOT
the Model: ST3151A04-1
the Type: of Si-a the TFT-the LCD, the CELL
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the HVA, of Black Normally, Transmissive
the Active Area: 697.685x392.256 mm
the Surface: Antiglare (Haze is 12%), the Hard coating (3H)
Glass the Depth: 0.70 + 0.70 mm
Transmissivity: 6.75% (with Polarizer)
the Contrast the Ratio: 4000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
Time The the Response: 6.75 (the G to the G)
the Frequency: 60Hz
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
