查看: 2071|回复: 2
AKIRA LCT-D26MT05ST
发表于: 2017-2-20 20:36:15
Plesk Panel: V260B1-L02 Rev.C1
The CON-the T: CM1671A the KQ-// MSDV2601-ZC09-01-BP's / of N: 303C2601053
Inverter (the backlight): MIP260B
The Supply the Power (the PSU): MIP260B
MAINBOARD: MSDV2601-ZC01-01 the CP / of N: 303C2601073
Tuner: the JS-6H2 / 121
rand: the CMO
the Model: L02-V260B1
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 26.0 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the TN, Normally the White, Transmissive
the Active Area: 575.769x323.712 mm
the Brightness: 450 the cd / m2
the Contrast the Ratio: 800: 1
Display Colors: 16.2M (6-bit + FRC), CIE1931 72%
the Response Time The: 3/5 (Tr of / the Td)
the Frequency: 60Hz
the Lamp the Type: 4 pcs CCFL Without Driver
the Signal the Interface: RSDS (1 Channel), 45 pins
Voltage: 5.3.3 / 5.0V (the VDD / VIN5)
 楼主| 发表于: 2017-2-20 20:38:36
AKIRA LCT-D26MT05ST
发表于: 2017-2-21 00:31:32
Akira brand LCD is rarely found in my region.But I may need its' firmware sometime.
So I took the link.Thank you again.
GMT+8, 2024-12-24 03:23 , Processed in 0.056140 sec., 9 queries .
