查看: 4066|回复: 4
TOSHIBA Model: 32A3000PR
发表于: 2017-2-18 10:13:15
he Chassis / the Version: A3000P
Plesk Panel: LC320W01 the SL the A1
MAINBOARD: PE0288
MAINBOARD the IC: the CPU: TC90403FG; Scaler: FLI8541BE
Tuner: ENG37E01GF
dditional technical information about the panel:
Brand: the LCD LG.Philips
the Model: LC320W01-SLA1
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the S-the IPS, of Black Normally, Transmissive
the Active Area : 697.68x392.26 mm
the Surface: Antiglare, the Hard coating (3H)
the Brightness: 500 the cd / m2
the Contrast the Ratio: 1000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 8/10 (Tr of / Td); 8 (the G to the G)
the Frequency: 60Hz
the Lamp the Type: Embedded EEFL 14 pcs (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-2-21 01:47:55
下载来看看了
发表于: 2017-2-22 12:05:04
感谢分享你的数据
发表于: 2017-9-14 10:32:18
看来是时候要补习一下英语了,啥也看不懂。不过,还是很感谢楼主的无私奉献。
发表于: 2017-9-14 18:48:06
谢谢了楼主分享啦
GMT+8, 2025-12-15 13:18 , Processed in 0.066322 sec., 9 queries .
