查看: 2732|回复: 1
TOSHIBA Model 26AV603PR
发表于: 2017-2-17 11:39:05
Plesk Panel: LTA260AP02 75014399
T-CON: 75015790
Inverter (backlight): 75015804
MAINBOARD: 715G3431 / 715G3385
MAINBOARD the IC: the CPU: MST9A885GL
Tuner: TAFT-S710D
Brand: the SAMSUNG
the Model: LTA260AP02
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 26.0 inch
Resolution: 1366x768, a WXGA
the Display-Mode: APVA, of Black Normally, Transmissive
the Active Area: 575.769x323.712 mm
the Surface : Antiglare (Haze 14%), the Hard coating (3H)
the Brightness: 450 the cd / m2
the Contrast the Ratio: 4000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 8 (the G to the G)
the Frequency: 60Hz
the Lamp the Type: 4 Embedded the CCFL pcs (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-2-25 00:33:03
下载来看看了
GMT+8, 2025-12-15 14:55 , Processed in 0.090287 sec., 10 queries .
