查看: 2649|回复: 2
TOSHIBA Model: 19DL833R
发表于: 2017-2-17 11:36:00
The Chassis / the Version: 17MB60-3.1
Plesk Panel: V185B1-LE2 the REV. C1
Driver the LED (the backlight): 17CON07-2
The LED driver the PWM: 3388DR
The Supply the Power (the PSU): 17PW05-3
The Power the PWM: ICE3BR1765J (the Standby), CAT7581
The Power the MOSFET: MDS5652
MAINBOARD: 17MB60-3.1
MAINBOARD the IC: the CPU: MSD9WB7PX; DRAM: HY5PS121621C; NAND Flash: NAND512-A
Tuner: DTOS403LH122E
发表于: 2017-2-17 12:16:58
   Many thanks to you for sharing hi-tech.
发表于: 2017-2-22 11:09:17
管理员能给翻译过来就好了  开不懂
GMT+8, 2024-11-22 15:10 , Processed in 0.052342 sec., 9 queries .
